Results 31 to 45 of 70
Thread: Carbbed 1UZ?
    User Conversion King
    NWA
    Default Re: Carbbed 1UZ?
    Quote Originally Posted by jeffro ra28
    i dont understand how carby can have a better result then a properly tuned efi
    the thread isnt about how good efi is over carby,
    its about retro fitting carb(s) for a hot rod style.
    EFI in a hot rod......im not sure if they go together.
    its like putting a 302 in a MA61..... errr wait, someones already done that
    hello
    Quote Originally Posted by willwal98
    I've heard quite a number of people say 450hp from a basically stock 1uz with the right carby.
    This is my point.... Lets leave it at that...
    ok, so 450hp.... Hows that translate into rwkw? what particular carby is the right one? and what supporting mods have been used?
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    How about some carbs for the look gutted and only for the throttle plates, and keep the injection and electronic spark.
    Just anodise the fuel rails blue and says it's NOS
    Everybody happy!
    Dan
    Long Time Reader Backyard Mechanic willwal98's Avatar
    from what i have heard the stock efi is tuned to be efficient. A decent efi setup would win hands down over any carby. Why don't you put a decent efi setup on but disguide it to look like a carby. you could put the injectors and fuel rail under the manifold to hide them or something
    Hello.
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Quote Originally Posted by ViPeR_NiPPleX
    Google tells me 450hp is 335.5 kW
    but that i'd expect to be at the flywheel, and even that, 450 is pretty general, could well be an estimation.
    If you want hot looking efi, itb's with big trumpets win hands down. Most idiots wont be able to tell the difference
    EDIT: 335kw at the fly would be a quite impressive.. but with stock cams, pull the other one.
  8. #38
    NWA
    you must have been speaking to this guy
    Last edited by brett_celicacoupe; 14-02-2007 at 07:37 PM. Reason: wrong comment quotted
    hello
  9. #39
    too be honest i would be surprised if that number wasn't exaggerated, and if it wasn't it would have many other mods. but i do think a big carby vs a completely stock efi motor would make slightly more power but at a huge cost to efficiency. and the same money spent on the efi would make more still. but i'm certainly no expert on these engines, just some grapevine style info. but it has been done so there must be info around somewhere
    Hello.
  10. #40
    that's the guy.. he drove a datsun 120y but his mate run 8's with his carby 1uz in his wb holden ute and still got 10L/100km
    Hello.
  11. #41
    450hp will be from carby, new intake manifold (one that flows), big cams, and a head port (a long with extractors etc)
  12. #42
    I know a guy with a wb ute, and it has a 1UZ, all toyota EFI tho
    Dan
  13. #43
    New Zealand
    They get 550hp from $60,000 1UZ race motors for speedway, from talking to a few racers you either go all out or leave it standard as there isn't a reliable mid point for the 1UZ. They run carbs due to class rules, not sure what they use for ignition.
    Callum
  14. #44
    What would those $60,000 race engines rev to? Would be sweet to have a 10,000rpm v8 engine in my 28 , would be sweeter having the 60g's lying around to pay for it
    Hello.
  15. #45
    New Zealand
    Not sure on the rev limit, not massively high though (7,500 -8,000rpm probably) as they are built for lots of low down torque to get out of the corners quick.
    Callum
    Last Post: 29-10-2021, 09:49 AM
  2. 1UZ aftermarket ECU option??
    Last Post: 04-08-2011, 08:07 PM
  3. 1UZ auto box options
    Last Post: 11-02-2007, 08:33 AM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
