Results 16 to 21 of 21
Thread: Which 4x4 transmission should I use
    tasmania
    Default Re: Which 4x4 transmission should I use
    what's the supercharger your running? i'm interested in supercharging later on, when i can afford it.
    beer me!
    Quote Originally Posted by Gabe
    The diesel AND petrol 5 speeds in the 100 series cruisers are substantially weaker.
    Thats because they are R151F's (or at least the one I drive is).
    i was going to suggest the r151, i know they came out in deisel surfs and good old shorty bundera
    The supercharger is an Opcon 222 on a Richwood manifold with a Richwood drive system. The blower is geared for 18lb but we're looking at upping that to 26lb when things are sorted.
    The engine will run:
    Ross 8.5:1 pistons
    Argo rods
    Kelford cams & springs
    ARP fasteners right thru
    Ported heads
    13/4" modified Tex headers
    3" exhaust with 2 hi flo cats
    Adaptronic ECU
    RX7 injectors
    Cometic h/gs
    Snow II water/meth inj
    I have all of the above on the shelf to go.
    Expected output is around 520hp and over 550lbft torque.
    I need to decide who to entrust the engine build to and away it goes. So I'm open to suggestions.
    Junior Member Grease Monkey MacroP's Avatar
    I'll say go for the H151F from a V8 100 series Cruiser wagon if you can find one -$$$. Toyoya don't release the manual anymore for the V8 but they were available. This should bolt straight up to the 1UZ. This box is still used today in the TD wagons(H151F) and TD utes/PC's(H150F - lower 1st, taller 5th). The R151F is used the NA Diesel wagons and utes/PC's only.
    As the 100 series cruisers weigh nearly 2.7tons and have a towing capacity of 3.5tons then this box should be up to what you want hopefully.
    MX83 1UZ Conversion. UZZ31 engine, UCF10 Sump, UZS131 Tranny and engine fan idler. Custom exhaust and 147rwKWs.
    tasmania
    Quote Originally Posted by zuffen
    Ross 8.5:1 pistons
    Argo rods
    Ported heads
    Adaptronic ECU
    RX7 injectors
    Cometic h/gs
    so a serious ball-tearing machine then... good luck, and please show us some pics as you progress
    beer me!
  1. A-series bellhousing to OLD T-series transmission
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 21-06-2008, 04:24 PM
  2. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  3. Auto Transmission Slipping in SV21 Wagon
    By Thraxeh in forum Tech and Conversions
    Last Post: 14-11-2006, 08:05 PM
  4. Replies: 19
    Last Post: 14-11-2006, 12:54 PM
  5. Century transmission - A60?
    By Norbie in forum Tech and Conversions
    Last Post: 28-08-2006, 04:42 PM
