Results 1 to 9 of 9
Thread: 4k cam into 5k
    Junior Member 1st year Apprentice kickn5k's Avatar
    victoria
    Default 4k cam into 5k
    I have checked the FAQ and couldn`t find it so here goes.
    Before i start pulling everything apart i just whant to know if doing the solid cam conversion you use the 4k solid cam?
    lifters and pushrods are not a problem will get custom, the cam on the other hand i need info as a billet is not available. Or do i just grind the hyd cam bigger?
    stu.
    Default Re: 4k cam into 5k
    you can get either ground to suit. I used a 3 or 4k cam when i converted mine to soild.
    Only did this in case i wanted to go back to hyro which i ended up doing.
    victoria
    What was your reason for going back to hyrdo cam as i can that ground.
    Thanks for info.
    stu.
    BOTTLE FED 1st year Apprentice madrolla68's Avatar
    Jun 2006
    W.A.
    Quote Originally Posted by kickn5k
    stu.
    Just get yours ground to a solid grind or use a 3/4K one
    victoria
    Quote Originally Posted by madrolla68
    I do have a solid in a 4k in shed. but i`ll prob grind the 5k a bit softer and get the solid nasty for when i do the offset grind stroker sorted.
    Thanks guys the bloke on the phone at wade cams wasn`t sure if they were interchangable.
    stu.
    Emo Slayer Backyard Mechanic rollin_stock's Avatar
    South Aust
    Kickn why use custom lifters and rockers? Have a look at the 5K lifter thread in this tech section.
    check the total lengths of the cams befor eplonking them in... i have suspicions that different length cams were used along the way (what with different depth plugs at the back.. and interference sometimes encountered)
    victoria
    Thats something wasn`t too sure about i`ll have a mesure before i deside.
    Thanks.
    stu.
    Jun 2006
    W.A.
    Thanks.
    stu.
    The difference in length is enough to lose camshaft endfloat and have the cam rubbing on the cam plug.
    Always check that the cam goes in below the block face and when its hard up against the cam plug and accordingly check the END FLOAT of the cam.
  1. 5K Conv to Solid Lifters (food for thought!)
    By rollin_stock in forum Tech and Conversions
    Last Post: 19-02-2007, 05:18 PM
  2. Twin SU HS6 on 5k
    By ke11restorer in forum Tech and Conversions
    Last Post: 12-11-2006, 02:00 PM
