Page 18 of 19 FirstFirst ... 816171819 LastLast
Results 256 to 270 of 284
Thread: How to: Supra MA70 rear discs to Hilux
  1. #256
    Default Re: How to: Supra MA70 rear discs to Hilux
    I was thinking the single pot would be better due to the much larger pad, but the opposing pistons would apply more force than the single piston and therefore not require as large a pad from what I can work out from your post above.
    The rear R32 calipers look like like an easy fit at this stage (with a very similar bracket to the MA70), they also sit very nicely over the disc. Maybe I will use them afterall.
    ([][][]II--LT--II[][][])
  2. #257
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    if you have them use them. prop valve sounds good anyway so you can set things up if something dosent work
    cheers mat
  3. #258
    ok i am about to do this conversion and i just read the whole thread and it gave me a headache!
    A summary of this thread would be good. Im wondering if there is anyone in brisbane who has done this conversion? Also im wanting to get the backing plates modified by someone who has done this before, anyone know what happened to linden?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
  4. #259
    Made some caliper adapters yesterday and have fitted the rear R32 Skyline GTS-T Calipers on MA70 Rotors with MA70 backing plates...
    Caliper adapter is quite simple, 6mm steel plate to bolt R32/R33 Skyline Rear Caliper to MA70-Hilux adapter. This way I can still go for a MA70 Caliper later if these, for some reason, turn out shithouse.
  5. #260
    sa
    does this brake conversion still apply to rn41 or any other diffs. looking for wider track.
    cheers mat
  6. #261
    Yep.
    I have it on my RN4# Hilux diff. I'm using different calipers as per my post above yours, but the RN4# diff uses the same caliper adapters as the RN2# diff for the MA70 conversion.
  7. #262
    sa
    cheers mate. now i just need to swap my rn27 for an rn41. anyone
    thanks mat
  8. #263
    Shouldnt cost you much to pick up a RN41 housing + axles, have mounts welded on and the center + brakes moved over from your RN25 diff.
    It is a pain in the ass though
  9. #264
    sa
    im on it but i dont want to pay $450 for it. thats what ive been quoted so far.
    cheers mat
  10. #265
    Apr 2011
    would this work on a 2008 Hilux, im sure the diff is fairly similar to the earlier models,
    and if it did work could you then use the adapter plate for the MA70 calipers to mount a Brembo big brake kit or something similar(from a MA70 supra)???
    cheers josh
  11. #266
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    I have considered this, and it should work.. But.. You will need something bigger on the front to match the bias.
  12. #267
    Apr 2011
    so if i went for something like
    front: 355x30mm disc with 6 pot calipers (this is a kit from the states that will fit a 2008 Hilux)
    rear: 330x20mm with 4 pot calipers, (something around them sizes??)
    and does anyone know how i could delete the stupid LPSV.
  13. #268
    Feb 2007
    No idea..
    You would also need to look at upgrading the master cylinder or you arent going to have a lot of pedal feel.
    I suggest starting a new thread, and asking your questions in there, rather than this old thread.
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  14. #269
    Feb 2011
    Old thread, but what is the smallest size wheels you can fit over these brakes? I am hoping 15's? as std ones were 16".
  15. #270
    Getting the RN2#/4# Hilux Diff to R32/33 Rear Twin-piston Caliper adapters made as I type this (finally), and will be for sale very soon for those wanting some. Price TBA.
    These adapters allow the R32/33 Rear Twin-piston Caliper to fit over the MA70 Rear Discs and Backing Plates as per my below post.
    Quote Originally Posted by twentyEight View Post
    I'm running R32 Rear Calipers (R32 and R33 Rear Calipers are identical) on my Hilux diff with MA70 Discs and Backing Plates, and they sit great! I will be getting a batch of 5 to 10 Hilux to R32 Caliper Brackets laser cut (1 piece design, as opposed to the 2 piece design I'm currently running) in the coming months and offloading them at cost. Can update anyone if they're keen.
    By The Witzl in forum FAQ
  2. EF/EL XR Falcon Front & rear disc brakes on a Hilux 2WD ??
    By ICELUX in forum Tech and Conversions
    Last Post: 26-08-2011, 11:08 AM
  3. hilux to supra diff centre interchangability???
    By millsi in forum Tech and Conversions
    Last Post: 17-11-2006, 07:04 PM
