Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 226 to 240 of 284
Thread: How to: Supra MA70 rear discs to Hilux
  1. #226
    Default Re: How to: Supra MA70 rear discs to Hilux
    I hated this task aswel, and i'd say best 20$ i ever spent was taking it to the brake shop to do for me
    jase
    JZA023
  2. #227
    im going to try and tackle this, this wkend, will take pics. no promises though. if you struggled with it, i surely will
  3. #228
    hey guys,
    looked through the thread and couldnt find this
    is this in the right order? also, you use a pipe to put the bearing on right?
  4. #229
    ok, so im gunna hijack here and post a few pics on how im doing things as the info isnt here (probably cos its so basic)
    inner bearing seal goes here like this
    use an old housing modified to remove bearings, a flat plate welded to box steel would work also
    then yeah use a pipe to put bearings back in
    bob is your nanny goat
  5. #230
    If anyone is doing this conversion send me a PM for a free set of Hilux axles. If not they will be going to the scrap metal bin.
    I used a bit of old pipe that was just the right size and some wood to press my new bearings home as well.
  6. #231
    Forum Sponsor Conversion King
    Quote Originally Posted by infotechplus
    The next two photos are NOT directions but questions aimed at clearing up the next stage of the process.
    If you can use one of the two pre-existing holes I assume it is the one I have marked. This means that to drill the other three holes requires a small part of the metal flange (marked) to be ground away. Is this correct? Have I got it right? Does this impact on the strength of this part of the backing plate (that holds the handbrake mechanism on the reverse side?)
    Assistance would be appreciated as I have to finish this and return the axles for re-pressing on the new bearings, etc.
    Peter
    Hi Pete,
    How bout you get rid of these 2 picures that way the 3 ppl that have followed this guide (which i told them to) using the pics rather than actually reading the text (which would take forever) won't have to get me to fix their backing plates up, or alternately replace them with pics of how to do it correctly
    Linden
    Edit: After reading the rest of this thread it seams like these photos have stuffed up a few more ppl than i thought, therefore complete removal of them is probly a good idea even if you have been asking a question and putting red writing above them.
  7. #232
    just looking at mine it look like i did mine like that also
    it means one of the nuts on the bit of steel that the drums connect up to doesnt get done up, they look like this
    are they fucked linden?
  8. #233
    yeah the one on the right is fucked ay
    linden can you PM me your address and a quote to get it fixed
  9. #234
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    After that, could you post the right pictures? So i dont fk mine up
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  10. #235
    What was wrong with that?!?
    I think my welder cut the wrong side of one of mine and had to remove both those tabs to make it fit. On the other, only one side was removed...
    My HB works though...
    Jase
    JZA023
  11. #236
    well if it was up to me i would leave it, all it means is that steel bracket on the back is only joined in 3 places instead of four and the housing is rotated a bit
    i dont intend on doing massive handbrakies on the drum brake cos i'll get a hydraulic one
    fuck i could just weld it in place
  12. #237
    Quote Originally Posted by Youngy
    are they 5 stud? i have run into some trouble with mine, can you please measure them from the grove where the circlip goes to the end of the shaft
    craig
  13. #238
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Tracking down the handbrake internals, can I use the JZA70 or GA70, are there any other donor vehicles I can get these parts from?
  14. #239
    Feb 2007
    Either is fine, other option is to find a Tarago.
    Details on which one are in this thread somewhere, it cant be just any old Tarago.
    The rotors are the same, but the handbrake internals may be different.
    Couldnt see why they would be tho.
    Herus
  15. #240
    They are 5 stud out of an RN85
    Yep the one on the right looks odd. See the relationship to where the handbrake cable mounts through that hole to the hub carrier.
    I can send some pics of my backing plates to someone to post up if need be. Yes you will end up with one blind stud and two bolts holding the handbrake pivot in place. Add a bead of weld where you grind things out and it will be fine.
    By The Witzl in forum FAQ
  2. EF/EL XR Falcon Front & rear disc brakes on a Hilux 2WD ??
    By ICELUX in forum Tech and Conversions
    Last Post: 26-08-2011, 11:08 AM
  3. hilux to supra diff centre interchangability???
    By millsi in forum Tech and Conversions
    Last Post: 17-11-2006, 07:04 PM
