Results 16 to 17 of 17
Thread: G-series Disk brakes (searched)
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Default Re: G-series Disk brakes (searched)
    Yeah i always use R31 calipers and disks for G-series conversions. For me, they're the easiest and cheapest way to convert G-series to disks. The most expensive part of the conversion is actually making up new handbrake cables to suit. I've yet to find a standard handbrake cable that will suit the setup (although i probably haven't looked that hard either ) I'm not sure what cables Rod used in his setup but i had some made up from scratch.
    If you're already getting your axles modified, make sure they machine and taper the centrebore to suit the disks you plan on using at the same time (its 68mm for skyline disks). Also depending on what Hilux axles you have, the outside of the hub may need to be slightly shaved by around 5mm or so to fit into the disk. But the bonus is that r31 disks come in 4x114.3 as standard.
    If you like, i can probably source another set of adaptor brackets for the r31 gear. Drop me a pm if you like. Also, mind if i ask where your getting the axle work done?
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Quote Originally Posted by gianttomato
    Hmm...can you get MA70 blanks from DBA/RDA now? Last I checked you couldn't.
    You can get blanks from DBA if you dont mind waiting for a while. The MA70 rotors are still made in the US and you have to wait for the next run to get them.
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 08:43 PM
  3. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 08:53 AM
