Results 1 to 6 of 6
Thread: 4agze head
    New Zealand
    Default 4agze head
    in the back of my 4agze head there are two sensors if i relocate those sensors can i just block up the hole or will it effect the flow of the cooling system
    sorry if this has been asked before but i counldnt find anything
    Default Re: 4agze head
    Yes you can block the rear water port with no probs, but its the best point to get the temps with ease!
    S.A
    I dont like the idea of blocking it off as the watewr pump draws the hot water from the back of the head.
    If it is blocked off That water at the back of the head will have nowhere to go and could cause a hot spot and possible gasket failure.
    Quote Originally Posted by 30psi 4agte
    If it is blocked off , it could cause a hot spot and possible gasket failure.
    Which is exactly right, and indeed the cause of failure on a smallport i did the HG a while back in. Crud had blocked the rear port, and while the dash temp sensor wasnt showing overly hot, the back of the head was reading about 120*C.
    New Zealand
    can i just join it to the heater hose tht runs under the inlet manifold
    If you mean the one which leads to the back of the thermostat housing. Then yes.
    There are a couple which lead along the back of the head under the inlet manifold.
  1. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
  2. 4AGZE head skimming
    By ohms in forum Tech and Conversions
    Last Post: 20-12-2006, 04:03 PM
