Results 16 to 21 of 21
Thread: Quick FPR question: Diagram Inside
    Default Re: Quick FPR question: Diagram Inside
    Yeah, otherwise your fuel pump could start dying, which will cost a lot more in repairs. (unless its like the uber bosch pump?)
    Perhaps its worth even going to a bigger injector again?
    Or converting to topfeed if you have the sidefeed 3SGTE rail?
    Depends how much power you want to get from her.
    I want another 25awkw on my 175kw/ 318nm it has atm. I thought a reg would get me over the line just..ohh well, thats what happens when you try and cut corners..
    pump is a walbro 255lph.
    rail is standard side feed gen2.
    Walbro's struggle seriously over 60psi, unless you get the hi-output version of it, which most aren't.
    42psi base + 18psi boost = 60psi fuel pressure.
    yeah, a 1:1 is not a rising rate, it maintains fuel pressure with increasing boost, but does not increase it.
    umm, my mind is fading from no sleep - someone else explain this coherently please
    Why would someone be using a RRFPR on a turbo motor?
    I thought only cheap people used them on NA-T conversions coz they won't fork out for an ECU
    Cheap people use it on turbo engines to fit a fuel cut defender (effectively clamping the injector output) and then refill the fueling requirements with the RRFPR.
    Very dodgy, but I guess it must work adequately enough for people to do it.
    Mos.
    im hitting max injectors on 6psi so have got the rr to wind the fuel pressure up a few psi.
    or to make the injectors big and strong ive used a rr to give me a bit more out of the injectors.
  1. Quick Dyno Tuning question
    By CoronaC in forum Tech and Conversions
    Last Post: 03-12-2006, 07:44 PM
  2. Quick question about driveshafts
    By Brett in forum Tech and Conversions
    Last Post: 19-10-2006, 12:19 PM
  3. Just a quick question ...
    By progkamol in forum Tech and Conversions
    Last Post: 14-07-2006, 03:01 PM
  4. AE86 full wiring diagram inside (incl. 4AGE)
    By Hen in forum Tech and Conversions
    Last Post: 12-02-2006, 09:01 PM
