Results 1 to 8 of 8
Thread: Diffs Differentials Diff Codes Transaxles and more
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Default Diffs Differentials Diff Codes Transaxles and more
    I know this is the question of a stupid noob but i've looked everywhere on the net and can't find the simple answer.
    When you buy an aftermarked lsd centre do you keep your ring and pinion?
    I don't know much about diffs..................
    Default Re: Stupid noob question
    Thats normally the case. You basically answered your own question whe you said "LSD CENTRE". You are just getting the centre and not the crown wheel and pinnion.
    you cant mix and match different ring and pinnion gears of varying ratios (obvious) nor can you even mix and match different ring and pinnion gears of the same ratio (due to the ware rate). there is nothing "normal" about keeping or throwing away the ring and pinnion set, cos it depends on what you're after, this is toy 'mods' not toy 'stock'. what i mean by that is; you may want an lsd, but for your application your may require a different ratio
    hope that helps
    craig
    not such silly question either
    Jun 2006
    ok thanks alot
    so i take it "crown wheel" is a synonym for ring gear.
    i was also under the impression that a diff's size (7", 9")was the diameter of it's ring gear.
    so to change my ratio, i have to change my ring and pinion anyway?
    Quote Originally Posted by Wedged'86
    ok thanks alot
    Correct...
    Jun 2006
    Ahh the world of differentials makes so much more sense.
    i have one more question though: does the size of the diff like 9 inch or 7 inch mean it's any stronger? i was also under that impression.
    Write English! Grease Monkey GasedT18's Avatar
    Default Re: Stupid noob question ( Diffs, Differentials, Diff Codes and more )
    Hi mate,
    generally speaking the bigger & heavier the stronger - that's why 4WD diff's e.g., Hilux, Landcrusers and trucks etc have big diff housings because inside are bigger bits that are needed to handle the higher loads. Not only the diameter of the crown but also the width of the crown and pinion gears are a factor in strength too as well as other parts that make up the internals, so there are diffs that have similar crown sized crown gears but have different load ratings and therefore what I started with is a simplification OK. Toyota G and F series diffs are often sought after for their strength.
    I can see from the direction of your questions that you probably have a lot more and there is a lot of information on diffs in this forum; not necessarily all of the common information in one place so it's worth searching but here's some links for starters:
    Toyota Diff Codes:
    DiffCodes.doc
    Toyota Transaxle Database / Diff Database
    http://toyotaaxle.norbie.net/
    This was put together with the input of a lot of people and a computer wiz member Norbie - thanks Norbie - and the thread of this colaboration is worth reading
    Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Tech Info: Toyota Differentials
    Differentials.pdf
    It's 21 pages, 288Kb in Adobe Acrobat PDF format - thanks Peter (aka infotechplus)
    Diff Pictures:- thanks river
    Exloded diagrams of some early model toyota diffs
    Choice of Gearbox Ratios and Diff Ratios
    This thread is worth a read to understand the interaction between gearbox ratios and diff ratios and the final drive ratio and has links to some wiz calculators
    diff ratios and combos
    Gearbox Codes & Ratios
    Gearboxes
    T-18 SE series 2 1982 3T-C dual fuel, now under resto
    3T-GTE rebuild with fancy gas bits under consideration
    AE71 CSX 1984 auto
    Parts Wanted ASAP - See Parts Wanted
    Jun 2006
    WOW!
    thanks alot for all that. i tried searching for diff info in the search but i never found all that.
    thanks again.
  1. noob question
    By joey in forum Tech and Conversions
    Last Post: 30-11-2006, 07:40 PM
  2. BOV question (noob alert)
    By Diz44zy in forum Tech and Conversions
    Last Post: 31-08-2006, 05:25 PM
  3. stupid 3tgte question(sorry is a real noob question)
    By lilcrash in forum Tech and Conversions
    Last Post: 20-03-2006, 06:13 AM
  4. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 12:37 AM
