Results 1 to 6 of 6
Thread: ae86 stock spring size
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    Default ae86 stock spring size
    hello,
    just wondering if anyone knows what the inner diameter and height of the stock rear spring are? mine are chopped, and i cant remember if they taper or anything. for the height, even a centre of wheel to guard height will do.
    thanks
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: ae86 stock spring size
    Inner diameter is 110mm no taper
    Uncompressed Height is 340mm
    by the looks of it, 4 free coils
    and a guess of about 10mm wire thickness, i don't have any verniers, not even cheap plastic ones
    dan
    wire diameter = 11mm
    outside coil diameter ~ 131mm (which could change when compressed)
    inside coil diameter ~ 112mm (which could change when compressed)
    free height ~ 340mm
    my guess is also 4 free coils.
    no taper
    according to my spring maker,
    the rear rate is 110lb/in (1.96437641 kg/mm)
    the front rate is 100lb/in (1.78579673 kg/mm).
    It's still kinda large, unless you haven't edited the pic.
    http://www.microsoft.com/windowsxp/d...powertoys.mspx
    go here and get a image resizing tool, right click you photos smaller, it's great for slow pos computers like mine.
    dan
    microsoft?
    hahaha, fixed the pic, but photochop is my weapon of choice, i use viewprint pro for quick stuff.
    thanks mate, here come the 5kg kmacs!
  1. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 03:40 PM
