Results 1 to 15 of 20
Thread: Individual vs Single Throttle Bodies
    Default Individual vs Single Throttle Bodies
    Hey all,
    just pondering the ins and outs of Individual throttle bodies vs single throttle bodies... mate of mine reckons that skylines retrofitted with the RB26 plenum and ITB setup end up REDUCING responce... i suggested it must be to do with the increased plenum size, though to look at, the '26 plenum isn't that large at all, probably not much bigger then the rb20 plenum...
    now i know some of the 4A's (20V etc) run ITB's, but they're naturally aspirated, not forced induction. i'll be the first to admitt that my experience in this field is limited, suffice to say i was under the impressions that a correctly setup ITB manifold would beat a correctly setup STB manifold anyday...
    secondly, are the gains (if any) worthy of investigating a ITB conversion? say modifying the likes of the 4A ITB's, or perhaps pilfering something from a motorbike, eg, suziki TL1000R (1000 twin = 500cc/TB) just a thought.
    '77 RA28LT #2 ← 2.2L 18RG...
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Default Re: Individual vs Single Throttle Bodies
    Quote Originally Posted by RAd28
    Surely he is wrong..........how would that even be possible???
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    Quote Originally Posted by Sir_2jza70
    Bad fuel tuning could do it.
    Or maybe an incorrect AFM/MAP setup.
    Montrose
    Is he just talking about that Zoom article from a while back, with a VR Commodore with an RB20?
    First thing to note: RB20's are seriously gutless off boost at any time, and any shortening of the runners etc. can only make matters worse.
    ITB all the way, can see it being worse with F/induction? dont know on what the gains would be on a turbo setup? but on N/A it made one hell of a dif for me
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    May 2006
    Quote Originally Posted by mrshin
    Ahh yes didnt think of that
    ... any shortening of the runners etc. can only make matters worse.
    well that's what i thought, a quick google search of RB26 plenums revealed they don't have 'runners' so much as well... stubby little finger things... the runners weren't any longer then the plenum was deep...
    so assuming that the ITB wasn't to blame in the case of the '20/6 would it be worth investigating for a turbo setup??
    Plus, didn't that article actually use an aftermarket GReddy RB26 plenum, which would've compounded any size problems?
    Jan 2007
    ITB,s on a forced induction set up do nothing , is why they take em off slowlines on the other hand N/A gives a little in hp but mainly fitted for response on twistys but again their are trade offs depending on runner length for N/A aplications .... If looking at ITB,s you have to look at the whole system from CAI to Zorst tip & where you want max TQ.
    @2C Keith:
    Quote Originally Posted by KGB
    That's not the reason they're taken off. They're taken off because they're harder to tune and their benefits aren't required on a drag car where a big single TB will do just fine.
    Quote Originally Posted by JustCallMeOrlando
    not refering to any article, just in general... but no doubt your right either way.
    so not much point in making ITB setup, better off making a decent plenum and STB setup then?
    Jan 2007
    Ok so i was being simplistic .... are you saying that he would get good gains for dollars spent by going FI ITBs instead of a STB regardless of what type of motorsport ...
    Keith:
    I don't remember saying it was good gains for dollars From a peak power perspective, if the plenum is designed alright, and the TB isn't a restriction, the power should be the same regardless. There obviously is some benefit to a well setup multi-throttle turbo engine in circuit racing, otherwise Nissan wouldn't have bothered to spend the coin on the GTR Skyline and the GTi-R Pulsar, both made for racing, and for the aforementioned reason, it's most likely response....but ONLY when setup correctly
    May 2006
    ^^Exactly! There is more to performance than just outright horsepower gains!
    MS
    Found this while looking at figuring the optimum trumpet length for an ITB project I'm working on...
    quoted from from www.jenvey.co.uk FAQ (who sells a Honda Bseries specific ITB)
    A. What is the best throttle body diameter?
    Factors influencing size are: Power output, rpm, cylinder head design, cylinder capacity, position of the throttle body in the inlet tract and position of the injector.
    Choice of bore size is a balanced compromise resulting from the following:
    1) A larger bore leads to lower flow resistance, but obeying the laws of diminishing returns.
    2) A smaller bore leads to better throttle control and response (never underestimate) and improved fuel mixing.
    3) The system should be considered in total - from (at least) trumpet flange to cylinder and proportioned accordingly.
    Basic references for BHP per cylinder, assuming ca.(ca.= approximately) 120mm from butterfly to valve head and a max of 9,000 rpm are:
    Up to 30 BHP/CYLINDER - 30mm
    up to 33 BHP/CYLINDER - 32mm
    up to 39 BHP/CYLINDER - 35mm
    up to 46 BHP/CYLINDER - 38mm
    up to 51 BHP/CYLINDER - 40mm
    up to 56 BHP/CYLINDER - 42mm
    Up to 65 BHP/CYLINDER - 45mm
    up to 74 BHP/CYLINDER - 48mm
    up to 80 BHP/CYLINDER - 50mm
    up to 87 BHP/CYLINDER - 52mm
    up to 93 BHP/CYLINDER - 54mm.
    These power figures may be increased by up to 10% in a purpose - designed, well proportioned system.
    As butterfly to valve distance increases, butterfly size will need to increase in proportion to system taper and vice versa.
    Lower revving engines and those with injectors placed before the butterfly will generally accept a larger body.
    B. What is the correct overall system length?
    Induction length is one of the most important aspects of fuelling performance engines.
    In our experience an under-length system is the greatest cause of disapointment, with loss of up to 1/3 of power potential. There are a number of good books on the subject and the serious developer is referred to these and, in particular, dyno trials.
    A guide figure, from the face of the trumpet to the centre of the valve head is 350mm for a 9,000 RPM engine. Other RPM are proportional, i.e. for 18,000 RPM the figure is ca. 175mm.
    The induction system is part of a resonant whole - from trumpet to exhaust outlet - and the ideal length can be heavily influenced by the other components.
    C. Which type of throttle body?
    Twin bodies are the most straightforward solution for tuning production engines, Direct-to-head where available, or via a suitable manifold.
    Direct-to-head-bodies represent the simplest and neatest solution.
    They are harder to match to the inlet ports if this is required for the engine in question, but have the advantage of being angled for best results, unlike a carburettor manifold.
    Single bodies represent the no-compromise solution. The seperate manifold is easily matched to the inlet ports and the best mixture path is guaranteed. They are also available in fully-tapered bore and twin injector types. Mounting, balance and maintenance are naturally more involved.
    D. What is the best position for the butterfly?
    The butterfly is an important aid to fuel mixing. When positioned too close to the valve this advantage will be lost whilst positioning far away may lead to a loss of response.
    As with the injector position , higher RPM demands a larger butterfly to valve distance. A practical minimum figure for a 7 - 9,000 RPM engine is 200mm, whilst the maximum is dictated by the need to fit an air horn of reasonable length to achieve a good overall tract shape. One solution to this apparent compromise is the use of bodies with fully-tapered bores which, in effect, extend the trumpet distance beyond the butterfly and into the manifold.
    For very high speeds above approximately 15,000 RPM, the ideal butterfly position is only just inside, or even outside the trumpet and a point is reached where a taper is no longer sufficient for good tract shape. For these circumstances we can supply bodies with the exponential trumpet shape machined into them as a special service, or barrel bodies which, by their nature, must be purpose-designed in conjunction with the cylinder head.
    E. Where is the best place for the injectors?
    For performance at low RPM, economy and low emissions the injector needs to be close to the valve and firing at the back of the valve head. This is the favoured position for production vehicles.
    For higher RPM (very approximately 8,000+) the injector needs to be near the intake end of the induction tract to give adequate mixing time and opportunity. The higher the RPM, the further upstream the injector needs to be. As a result, use of speeds above approximately 11,000 RPM may give best results with the injector mounted outside the inlet tract altogether (see our remote injector mounting). It is common to fit both lower and upper injectors in such a system to cover starting and low RPM as well as high speeds.
    Where one injector is to be used per cylinder the best compromise position is immediately downstream of the butterfly. This gains maximum advantage from local turbulence and gives results surprisingly close to the optimum at both ends of the rev-range. This is the recommended position for most applications.
    F. What is required for a complete fuel injection system?
    Besides throttle bodies, linkage and manifold (if required) typical components are; A management system, wiring loom, fuel pump, fuel pressure regulator, fuel injectors, appropriate plumbing, air horns and a ducting/filtration system for the incoming air.
    G. What type of injector?
    I. Injector Dimensions :
    All Jenvey injector mountings and fuel rails will accept the standard 'O' ring mounted injectors for 14mm bores as supplied by Bosch, Weber, Lucas, etc. These are typically 63mm between 'O' ring centres.
    All except the diecast aluminium fuel rails will also accept the shorter 'Pico' style injectors. Please specify which you are using when ordering throttle bodies and fuel rails.
    There are a number of other injector types, using the same 'O' rings but with a different length. These can be used on our twin throttle bodies with ease, but may require special fuel rail mountings on individual bodies.
    II. Injector Flow-rate :
    When fitting our throttle bodies to an otherwise standard engine bear in mind that increased power means increased fuel demand and the original equipment injectors are therefore usually inadequate.
    H. What manifold to use?
    When injecting into the throttle body, most of the mixing occurs within the manifold section. It is therefore important that the manifold is suitably proportioned to evenly accelerate gas speed and thus help fuel mixing and distribution. The straighter the run in to the ports the better. A manifold which curves in the same direction as the valve throats is preferred to one which causes the gasses to undergo an "S" bend.
    RA65 SCCA Car (looking for a decent swap)
    NCP61 Daily Driver (pondering the practicalities of making it a SCP61)
  1. Quad throttle bodies
    By MiC in forum Tech and Conversions
    Last Post: 28-04-2006, 08:50 AM
  2. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
