a super charger? ha ha.
Does anyone know if a 22re has had a sc14 attached to it, what would be needed for the process.
I think i've read about someone in the us doing this b4 or maybe it was turbo.
1UZ-GE RA28 The Dream....
....Some days we wake up to dreams!![]()
Leva morena me leva, me leva pro seu bangalô
thanks for your helpOriginally Posted by simple61
perhaps that is funniest first post i have seen
you would need brackets to mount the SC, pulleys (spare section on crank pulley? longer belt and altered path of stocker?), and piping..... IC would be good.
it' s a little small for big performance, but should be able to get sayyy 6-8psi for the revs the R is likely to use... make it more torquey but worth the effort?
oh, and search![]()
http://www.google.com.au/search?hl=e...harged&spell=1
Modified 22RE FTL
shouldnt be to hard the 22RE had aircon right? that bracket could come in handy
yanks have been modifying these truck motors for a long time. turbo and supercharged.
sometimes you haev to work with what you have![]()
and also, why not... bit of fun perhaps
phobia on these forums has a 22rTe its succesful to a point, the head being the limiting factor if I remember correctly.
I suggest giving him a PM and checking with him as to whats easy/worth it. Thats what this forum is here for, to learn from others mistakes, I mean experience![]()
i just like to stir him up!Originally Posted by oldcorollas
I think its a great idea, if you do a search u will find a thread i made (or maybe i was just very active in) a few months ago. Apparently, the stock afm and ecu will cope with low boost, all you really need is better injectors (7M-GE's were what i was looking at).
Use USA ebay and buy some forged "turbo" pistons for cheap, with the standard 22R-E head it will make 9.0:1 compression ratio, perfect for low boost.
All the information you need is on google (as posted above), as its been done many times before in the usa.
Good luck.
Originally Posted by skiddz
paradise racing and brd racing would deffently have some info for you
IMO it's a great idea if you want a super-torquey engine for towing stuff in your Hilux, but if you're after performance it's a crap idea.
Mechanically setting it up is pretty straightforward (but not necessarily easy), do as described above. I'd recommend decent engine management if you want to get the best out of it, even just a $1000 Microtech would be a huge improvement over fudging the stock management.
Norbie!
www.norbie.net
dont knock it unless youve tried it...
i know your on celica-gts.com find 83GTCoupe on there and send him a PM or have a look
for his write up, he has a Supercharger on his RA64 and has gotten some great results
(not his only mod though) they do make a full S/C kit and turbo for the celica![]()
3xRA60's (one ga60)
3x Supras (2x jza80- 1xma61
EL XR6 Tickford
AU Falcon, EX-Taxi Spec.
VR Commodore...
This page, http://www.cardomain.com/ride/551439/10 and the next few pages.
And this is the direct like to the celica-gts.com 83GTCoupes write up
http://www.celica-gts.com/forums/ind...topic=6389&hl=
