Results 16 to 21 of 21
Thread: Can an engine ping under medium load even if it doesn't ping under heavy load?
    sa
    Default Re: Can an engine ping under medium load even if it doesn't ping under heavy load?
    So it does it at a particular rpm under any load?
    Sounds like piston slap - as I mentioned.
    I see invisible people Backyard Mechanic WHITCHY's Avatar
    New South Wales
    nah its definately a throttle point, i tested again today, its the same going up or down or on a flat, if I hold my foot at light throttle and let the revs get all the way to 6k there is no pinging noise anywhere, but as soon as I put my foot to that certain point close to 50% throttle the noise starts! as soon as I plant it to WOT it disappears, I am pretty sure it is pinging now, I was forced to run 91ron petty yesterday and the noise was still the same, but didn't dissappear at WOT, back to 98ron today and its there at med throttle position, but not at light of WOT!
    Its definately something to do with the throttle position. the ecu is tuned using the TPS also instead of MAP sensor so it might have something to do with that!
    Cheers.
    -Whitchy-
    If it happens in neutral then i really doubt it is pinging unless the mixtures are stupidly lean (which they didn't appear to be when I checked) or the timing is really advanced.
    It could be something tapping or rubbing or something. Didn't really sound like a normal pinging sound to me when we were driving.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    nah it doesnt make the noise in neutral, its just at that certain throttle point,
    10 characters
    Junior Member Backyard Mechanic 1jzracing's Avatar
    read my post earlier .... i know its a little bit double dutch but its a common issue running multi TB's and load from the TPS
    i had the same thing when i first started running multi's on my beemer
    when you are at half throttle with throttle bodies and load is read from TPS your actually running the engine at the equivilent of nearly wide open, your getting cylinders filling really well even though your accessing a point only half way up the ignition table so you need to run much less timing (and more fuel) in the mid range than you would on the ignition table of a MAP sensor set up, if it was reading load from MAP it would be accessing a point right up near the full load area
    at wide open your getting more cold air, more fuel, and on most ignition tables less timing than part throttle so it stops pinging
    other major factors are things like the runner length and so on that play funny games with the tuning on a multi TB set up too so there can be some funny waves in the tuning tables, in general the timing on mine had to be a little less than normal with the multi set up because its so efficient
    just keep pulling the timimg back in the areas where its pinging ..... FIXED!!
    even if it looks to be in a bit of an unusual area
    a fool remains undescovered untill he speaks!
    I've had a similar thing happen in my Celica. it still happens even now. I reduced the timing first, down to about 7* (normally ~10*) and not only did it feel like a dog to drive, but it did nothing for the ping.
    tried using 95 and 98RON fuel, neither of which helped the ping. it's more noticeable on warmer/hot days than other times, which made me think about detonation.
    I replaced all accessible vacuum lines with silicone, as a lot of them had perished. it still happens around the light/mid-throttle mark, but if you plant it it disappears.
    anyway I'm convinced my engine is dying... I can smell burning oil whenever I shut the car off after a run to Lismore and back, which I'm sure isn't good.
    Just thought I'd share my similar experiences and throw in my 5c worth (lowest common denomination of legal tender!)
    TRIKKE | Video
  1. MA70 --> JZA70 Conversion
  2. Cooling Systems - Overheating Problems.
  3. Heavy Duty Engine mounts - Where to buy?
    By DiZ in forum Tech and Conversions
    Last Post: 19-04-2006, 10:11 PM
