can you just fill your old ones with urethane and let them set? =)
I am having trouble tracking down some new heavy duty engine mounts for my 4AGZE, now the mounts I want to replace are the same as the 4AGE mounts.
The front timing case mount and the mount at the very end of the gearbox.
I had tried to get them through noltec but they only make the front gearbox mount. I do however have a spare end gearbox mount I am taking there to see if any other inserts that make fit the bill but I am highly doubtful. If they find an insert to fit the end box mount , would the end box mount and the front timing case mount take the same insert or do I need to find a front mount to take and get another insert matched?
Where do you people get your heavy duty 4AG engine mounts?
Corolla dead
GTiR now
I had the same problem. All i did was take my mounts to noltec and they made urethane ones for me.
There was no chance in hell they would ever break either. I did notice a little more vibration with them but not enough to bother about.
Im not sure what exactly you are asking them for but i gave them the whole mount.All four as a matter of fact. They pulled the inserts out, put a new bit of metal through the centre and filled around it with urethane.![]()
I thought they would have been able to help you...........interesting....?!
FATMR2 SAID
"They pulled the inserts out, put a new bit of metal through the centre and filled around it with urethane."
how much does this cost for 4 mounts??
yep go custom youll never look back!!!![]()
Only problem is that Noltec no longer do custom afaik (from: http://www.toymods.net/forums/showth...=noltec+custom)
Specifically this post (http://www.toymods.net/forums/showpo...84&postcount=9) by Toobs
Any idea if they would make a custom sized set of engine mounts ? Im putting a RB20DET into my RA60 celica (it works out better than a 1GGTE) but i may need a custom sized mount. Anthony Callum has made up the engine mounts for the RA60/65 celica to fit the 1GGTE, but i dont have contact with him so im unsure how he made them. Any ideas ? Sorry to hijack the thread but i feel its sort of part of your question, only a little further lol
wes.
Bitch, come over here and have sex with Charlie Murphy..
Im Rick James bitch!
Just fill the gaps in the standard mounts with the hard version of Sikaflex. You won't break them after doing that.
