Results 1 to 4 of 4
Thread: 1ggze no signal from IGT to igniter...HELP!
    Mad Man Grease Monkey 77GZE's Avatar
    Default 1ggze no signal from IGT to igniter...HELP!
    Hey guys, ive just about got it running on the stand, just the ECU is hitting fuel cut immiatly after turning it over because IGF isnt sending a signal back to the ecu. Mainly, becuase there is no signal getting to the igniter to start with...
    what else could it be besides fucked ecu?
    All signals from the CAS are good, and IGB and IGA are good.
    Steve
    Default Re: 1ggze no signal from IGT to igniter...HELP!
    stock ecu?..... is the ignitor bracket earthed as in, bolted to the block or engine stand...
    Junior Member Grease Monkey Jasper's Avatar
    Any progress on this Steve?
    Have you hooked up the diagnostic stuff yet?
    Yep got it running mate! Just got a problem with the ECU now NO odd injector pulse. Even injectors pulse. Spark on all cylinders, but only 3 cylinders fuel!
    AHHKK gotta try another ecu, then if thats not the problem, ill start looking for other issues.
  1. mx83 1jz auto issue
    By jeffro in forum Tech and Conversions
    Last Post: 16-02-2014, 08:47 PM
  2. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  3. 1ggze No spark!
    By 77GZE in forum Tech and Conversions
    Last Post: 18-01-2007, 08:41 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
  5. Effects of no SPD signal to ECU?
    By Drifty Midship in forum Tech and Conversions
    Last Post: 29-03-2006, 12:47 PM
