Results 1 to 5 of 5
Thread: 13bt Into 79 corona 2000
    Nsw
    Default 13bt Into 79 corona 2000
    Now ive searched and really want this info, got the engine and the car just need the destructions
    help would be appriecated
    regards
    jack
    Default Re: 13bt Into 79 corona 2000
    I haven't heard of it being done before.
    Basically the same as any engine conversion.
    Take out old engine.
    Plonk in new one. See where you want to mount it, what fouls etc. Determine engine mounts and gearbox mounts.
    You will need an EFI fuel pump so if your car isn't EFI probably best to go surge tank setup.
    Brakes will need to be upgraded. Don't know if the xt130 shocks with pug and hilux bits fit on your model?
    Diff will probably break. Find out what model it is and see what other people have done with them. Probably Hilux diff conversion though.
    Depends on how much power you are aiming for. Stock 13bt (with no torque j/k) probably wouldn't be that hard on the diff but if you are looking at turbo upgrades etc. then probably best to go for a Hilux diff or cut down 9".
    Hope that helps.
    BTW probably good idea to check www.ausrotary.com to see if anyone has done it as well.
    They like using corona 4 spd boxes as well so if you have one, use it
    QUICKEST 1JZ'S IN OZ
    You have probably alreay thought it, but ill say it anyway.
    Use a W58 or even the stock W50 gearbox and get the 13b bellhousing for it, then mate the engine to it and make the mounts so it fits.
    NB: W50 box is generally called "celica box" and W58 "supra box", but the people at dellow will know what you are on about anyway.
    Nsw
    Yea its a 4 speed, just thought it would be the ultimate commadore confusion, considering its the only things they drive up here in tamworth thanks for ideas and help lads
    Junior Member Grease Monkey MAD79R's Avatar
    i have an old copy of Fast Fours& Rotaries FEB/MARCH 1998 that has a 74 Corona with a13BT in it if you want to BORROW it let me know where you live and will sort something out Steve
    (\__/)
    (")_(") ITS ALIVE
  1. 1G-GE into MX22 MK2 Corona.
    By crowncustom in forum Engine & Driveline Conversions
    Last Post: 12-01-2009, 07:48 PM
  2. ST171 Corona running celica GT4 hardware?
    By cylinderhead in forum Tech and Conversions
    Last Post: 14-07-2006, 11:43 AM
