Results 46 to 52 of 52
Thread: electronic boost controllers
  1. #46
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Default Re: electronic boost controllers
    Quote Originally Posted by cri_ag
    yea cheers dude, i bought a blitz dual sbc spec r and i love the thing, rock solid boost control and nice small head unit, the id3 is a great unit to, a couple of the other boys are using them too.
    Apparently theres another unit which links via Infared with the one i have, a Power meter or something. Can't wait to get it
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
  2. #47
    my $0.0 a/c idle-up soleniod dual stage boost controler still works well.
  3. #48
    Good choice on the controller I have the Blitz DSBC Spec S and find it regulates the boost beautifully I do get a bit of an initial spike, but I could probably just turn the gain down a bit to fix that. I just put some velcro tape on it, and stuck it near my left leg in the drivers area. I can always pull it off the velcro and tuck it under the carpet if the law wants to take a closer look.
    244rwkw / 328hp @ 18psi
  4. #49
    no spiking on mine,deff turn the gain down a bit to fix the spike. i ripped my ashtray out and put it there, i plan to cut the back of the ashtray out so i can slide it back in and cover the controller up when stealth is required. for the price of the things i reacon they are sweet!
  5. #50
    johor
    How well does EBC works with stock turbo actuator? Im looking for the same requirement as the thread starter, i only need something ability to hold the actuator totaly shut untill i see the set boost level. Coz im running on Auto transsmision, so i do not need the gear shift turbo set level.
    I do heard Blitz unit doesnt last long as well. pls correct me if im wrong
  6. #51
    My Blitz unit is fine, lasting well so far. Just play with the gain setting to make it build boost faster. The higher you set the gain though the more likely you are going to get a spike/the bigger the spike.
  7. #52
    Grandma Driver Grease Monkey h0mbre's Avatar
    Jun 2007
    I bought a Gizzmo today for a pretty good price.
    Goes in tomorrow, I hope it holds the boost well!
    Chaud! Pas Toucher
  1. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  2. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  3. Boost Leak Tester
  4. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
