Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
Thread: 20v sounds like a diesel
    Junior Member Grease Monkey bje10s's Avatar
    Apr 2007
    Default 20v sounds like a diesel
    hey i just picked up a ae92 20v silvertop and it sounds like a diesel.
    my friend told me it might be the vvt seal?
    is there any truth about this?
    everthing else is fine with it. i gave it a full service just to rule out anything oil quality related.
    im stumped
    Default Re: 20v sounds like a diesel
    Is it running on 4 cylinders? does it have an exhaust leak?, is the engine vibrating more than usual?
    Apr 2007
    im guessing its running on 4cylinders. it still goes really good performance wise so i guess it is .how would you tell noises etc? i cant see a exhaust leak. and no vibration. i tell you i have no clue what this could be. i have done the whole car service oil etc, coolant etc, brakes etc, grease etc. i checked the coolant and its not a oil leak.
    the only thing might be that 3rd gear syncro is crunching not bad tho. still i wouldnt think that it could be that?
    Junior Member Backyard Mechanic pAuL's Avatar
    20v's are 4 cylinders aren't they?
    Current - 2006 Colt Ralliart 100.2FWKW@6000rpm,
    Past - 1988 Toyota Camry V6 (Sold) (VZV21) 117kw@5600rpm, 1994 Lancer Station Wagon Executive (sold) (86kW+@6000rpm), 1986 Corona S (sold) (73kW@4800rpm), 1990 Cressida GLX (BHG) (142kw@5600rpm)
    Apr 2007
    yup they just have 5valves per cylinder hence 20v they are 1.6L 4age 20valve
    Western Aus
    Quote Originally Posted by BeRad
    ehehhehehe.
    silvertop, if its still running on factory ECU, (AFM still retained) then you have a vacuum leak.
    if it chugs, carries on, idles rough, but is fine higher up, while the motors under load, then its a vac leak.
    Elmo.
    Apr 2007
    nup lol no vac leak either. im telling you this is a hard one. idels perfect, runs perfect just sounds like a diesel. ahhhhhh i hope this isnt something really bad or costly.
    Junior Member Carport Converter 4agte's Avatar
    mine is very tappety aswell i would assume that the valve clearance in my head needs adjustment with some new shims
    The vvt cam pulley is known to clag up, once this happens it goes all clackety clack.
    You should be able to isolate the noise fairly easily.
    This happens because people tend to skip services in Japan, good news if you are dumping the car in a few years, bad news for people buying them later down the track
    Dan
    explain clag up................
    Sounds like a faulty VVT pulley.
    http://www.rollamods.com/main.htm
    Under VIDEOS
    Go to the "testing faulty vvt" clips 1 and 2 and check to see if it similar.
    i couldnt find it maybee im blind
    fixed post ;-)
    Apr 2007
    Quote Originally Posted by sxtool
    Under VIDEOS
    yep thats the sound!!!!!!!!!!!!!!!!! so i guess this prob is somewhat common??
    ok ow the question is how do you fix it???
    thanks boys
    $300-400 for a new AE101 intake pulley from toyota.
    Blacktop item is closer to $800.
  1. Quick question re: turbo diesel
    By tangcla in forum Tech and Conversions
    Last Post: 15-04-2007, 02:04 PM
  2. Opinion : Using Diesel as an oil flush
    By Grega in forum Tech and Conversions
    Last Post: 27-11-2006, 05:30 PM
  3. 2L diesel pump seal replacement.
    By beterthenu in forum Tech and Conversions
    Last Post: 19-09-2006, 07:20 AM
