this thread is for Nathan's (TA-022) car
he has done some extensive measuring and implemented an RA60 crossmember into his ra28 (which would give both R&P and power steering, but has rear facing crossmember, ie front sumped engines). it gave wider track but from all accounts was a successful transplant.
it starts at post number 57 in his readers rides section.
http://www.toymods.net/forums/showth...+Celica+Spares
MWP used an ae82 rack o connect to a ta23 crossmember (same as ra28 crossmember but rear facing like the ra60 above)
joel (turbora28) used a ke70/ae86 setup as mentioned already above
brett used an mx62 power steering box in the ra40 as mentioned above...not quite the same as an ra28 but i am sure it isn't too far out.
http://forums.toymods.org.au/index.p...t=0#msg_381106
here is a web page for some ra60 r&p conversion into ra28/ta45
http://ourworld.compuserve.com/homep...#RackAndPinion
note that the 18r in your celica currently would have a rear sump on it so all the options above hich change the crossmember, you will need to find a front sump at least to avoid fouling issues, these are plentiful on coronas around the same ear i think (i saw at least 6 front sumped 18r's at our local wreckers).
none of this is will be for beginners.
probably brett's approach would be the easiest, best, cheapest wayy to start and he has recommended you don't worry about it so there you go.
