Results 16 to 20 of 20
Thread: 4agze/fe pistons in a 7afe
    Default Re: 4agze/fe pistons in a 7afe
    Quote Originally Posted by Cameron_Datto
    From what i have read the conrods are more the worry , rather than the pistons , personally i wouldn`t change the pistons if you still got Std 7a rods . oh well its your engine So its your call on what you use , my 2 cents
    Rods AND rod bolts are the main problem......but fix them up and chances are the crank will go next.
    GameOn Backyard Mechanic Poggy's Avatar
    my 7afe has seen 6800rpm ever day for 100,000kms and it was fine
    th reason i want to you a diff piston is to raise the compression ratio up from 9.4
    Is there room to machine the head?
    Quote Originally Posted by Ben Wilson
    heads getting shaved as well, alot i'm taking material out of the combustion chamber, plus i want a full floating piston for better reving
  1. Higher comp pistons for 4agze ?
    Last Post: 15-04-2007, 04:48 PM
  2. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  3. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
  4. 7afe h/g vs TRD h/g
    By Mr Revhead in forum Tech and Conversions
    Last Post: 13-10-2006, 11:42 AM
  5. wiseco pistons for 2tgte
    By cooter in forum Tech and Conversions
    Last Post: 02-10-2006, 04:26 PM
