Results 1 to 15 of 20
Thread: 4agze/fe pistons in a 7afe
    GameOn Backyard Mechanic Poggy's Avatar
    Default 4agze/fe pistons in a 7afe
    Hey guys,
    Well i'm rebuilding/spicing up my 7afe, yeah i know what youre going to say " Why bother" but anyway, i'm looking to knock the compression up to around 11, there are a few ways that came to mind.
    1. Use a 4agze flattop 40/60thou piston plus headshave, sleeve my 7afe conrod and use full floating. " this will produce a higher comp then the 4afe piston"
    2. Use 4afe 40/60thou piston plus headshave which has less dish then 7afe, would also convert this to full floating.
    I wanted to go to a drop forged piston, or something a little stronger then the standard 7afe piston.
    One big problem i'm looking a is the valve cut marks in the top of the pistons, on the 7afe they are deeper towards the center, on the ge pistons is different due to the valve angle, i know it wouldnt really pose a problem unless a timing belt snapped, but what do you guys think? would the gze piston be a better option, also can i can aftermarket conrods for the 7afe, something a little stronger.
    Cheers.
    Default Re: 4agze/fe pistons in a 7afe
    dunno about piston-to-valve clearance issues with the 4A-GZE pistons, but they would be my number 1 absolute choice.
    Factory forged, and $400 a set from Toyota.
    Junior Member Carport Converter 4agte's Avatar
    are you going forced induction or n/a cause arent the factory gze pistons rather heavy
    http://forums.toymods.org.au/index.p...t=0#msg_200356
    ... looks to be around the 300g mark without pin.
    Quote Originally Posted by Poggy
    Ze pistons aren't flot top, they have a dished top.
    Sounds about the same as a 7A piston anyway, at least the one that I modelled.
    what was left of MrShins piston weighed 298.12g
    so that means its the full weight of a piston intact.......?
    Quote Originally Posted by Ben Wilson
    sorry what i ment was there are two 4agze pistons, one is dished, the other is slighty dished close to flat top
    Its going to be n/a, the 4agze piston will be better in my mind, due to the full floating, it wil lsnap/rev quicker
    piston weight for GZE AE92 0.5mm oversize
    about 305grams
    pin weight = 100grams
    total, about 405 grams
    the vague weights of pistons posted by Kingmick (even though he never bothered to post if they included pins or not ) indicates that other aftermarkets are lighter.... but bang for buck...
    the dish volume should be easy to find also.
    righto cheers for that i had the impression that they were alot heavier +rep
    and in that other thread, Ben Wilson showed the blacktop 20V pistons (including pins) were abotu the same weight as the GZE slugs!!! (so rep him too ), but he suggested the silver top ones were lighter...
    arias makes an 82mm "flattop" piston Comp ratio with stock head is 8.6:1 it has a dome CC of -4.3 that should make the comp ration around 10.8:1 - 11.1:1
    Every factory 4AG piston I've found reference to is around the same weight.
    gze pistons will knock the comp ratio up around 1.5:1
    South QLD
    From what i have read the conrods are more the worry , rather than the pistons , personally i wouldn`t change the pistons if you still got Std 7a rods . oh well its your engine So its your call on what you use , my 2 cents
  1. Higher comp pistons for 4agze ?
    Last Post: 15-04-2007, 04:48 PM
  2. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  3. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
  4. 7afe h/g vs TRD h/g
    By Mr Revhead in forum Tech and Conversions
    Last Post: 13-10-2006, 11:42 AM
  5. wiseco pistons for 2tgte
    By cooter in forum Tech and Conversions
    Last Post: 02-10-2006, 04:26 PM
