Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: 7mgte + bleed valve + boost gauge = 5psi?
    Default Re: 7mgte + bleed valve + boost gauge = 5psi?
    Quote Originally Posted by Bored?
    When I did mine, I noticed that a number of the rubber hoses between the turbo and throttle body had cracks in them due to age and heat, so I replaced them. You might like to check your car for similar problems, since a big boost leak could also stop you making much boost.
    The flexible pipe that attaches to the throttle body was the worst. Replace any problems with silicone hose.
    Please also be very careful with the material used to replace these hoses.
    For example, any of the PCV hoses need to be replaced with a special type of hose, otherwise the oil gases will eat away the hose and you'll be left with chunks of rubber in your engine (this is why replacement PCV hoses from toyota are so damn expensive).
    most decent quality silicone hoses are able to withstand fuel fumes and oil.....
  2. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  3. Boost Leak Tester
  4. Turbosmart bleed valve
    Last Post: 27-04-2006, 08:57 AM
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
