your heater valve could not be turning off, in most cars the coolant flow to the heater core in the HVAC unit is controlled by a valve.
get someone to turn the temperature control from full hot to full cold, you should be able to see a cable operated valve moving in the engine bay that will be attatched to some heater hose, someone with a similar car should be able to tell you where to look for it.
another problem could be your air temperature control door not moving all the way to full cold (in the heater box) and will need adjusting, which could be a trim/dash out job.
yet another problem could be that the blower fan could be sucking in hot air from the engine bay, but this isn't so likely.
Nicola Blake
