Results 1 to 15 of 21
Thread: ok...now next stage, EXT WASTEGATE MOUNTING POSITIONS?
    Default ok...now next stage, EXT WASTEGATE MOUNTING POSITIONS?
    well now that i have my gate,
    im trying to fing a place to mount it... does it matter with gates how they are mounted?...ie lying flat,?
    im very pressed for room to move with it....and can see the only place to mount it will be lying flat...
    any hints or tips you have for mounting ext gates will be rewarded if i havent allready givin u love!
    cheers, blake
    Default Re: ok...now next stage, EXT WASTEGATE MOUNTING POSITIONS?
    be very careful with how the gate pipe mounts to the main manifold.. so that it actually gets flow, and is not "shielded" ?
    you would hope that the forces involved are greater than the gravity effect on the pistons..
    heat shield it... choose position to maximise distance from damagable stuff.. then put radiant heat shields etc...
    is it heavy? need a brace?
    Junior Member Grease Monkey Jasper's Avatar
    Got engine bay pics?
    I'm about to head up to the workshop and continue making my manifolds...
    well.... no pics yet...
    the mani is a low mount...., and where the collecter sits, ive had to modify it....move the T3 flange plate down a bit so that the wastegate pipe isnt sitting behind 3 pipes (sort of inside the collector....).
    .....ie so it doesnt sit too high in the collector that it will only get directional flow of 3 cyl/pipes...
    the gate is a 46mm, bit biger than the size of a coke can...so it will be braced up,
    ive found a new spot, it will be siting upright..., tucked in between, clutch master cyl.....manifold and the firewall...above the steering box....
    basically in the same position as the rear turbo on the stock set up...
    Quote Originally Posted by Jasper
    ahaha im at the shop too...but i suck...first turbo conversion for me....
    Rosewood
    http://www.turbosmart.com.au/index.p...download&id=29
    The above turbosmart install guide has a good explanation of wastegate position, and the best position to put it.
    and you'll be mounting at LEAST a single layer of alloy or steel sheet as a radiant heat barrier to the clutch master... ie, say 1" away from the clutch master (so that heat can't directly hit it from ANY part of the exhaust), and if you are feeling special (and safe) have a second layer 5-10mm further... you can join the two...
    this will stop the clutch master from either boiling, melting or burning, and you from having no clutch at a very bad time
    lying flat wont matter at all, make sure you vent from the collecter, in the following dodgy explaination if possible
    if you imagine the turbo manifold as a Y the collector is the bottom bit of the Y, the turbo entry is one of the top bits of the Y and the gate is the other top bit of the Y.
    if you can, plumb the waste pipe seperately as this will give you better boost control (with a muffler, as screamers sound gay) or plumb back into the dump a fair way back with a shallow entry angle.
    also, buy maximum boost (the book by corky bell) if you dont have it already.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    I highly the BA falcon heat shielf material for this... bendable aluminium sheeting, very good. Joorsh used this on this 2j ma61
    yeah thats the shit, pretty sure you can buy it by the sheet from ACL or the like
    www.vicdrift.com
    As a result of being glued to the cricket, and all the booze I got for Christmas, I got fuckall done this afternoon/evening. Here are some pics of the basic layout of the collector where the wastegate feed will be:
    I'm not happy with the length of the merge going into the turbo flange, and will make a much longer pair tomorrow.
    Quote Originally Posted by -==L=a=N=c=E==-
    awsum read dude!....thanks for that!....clears a few things up!
    dont worry bout that....ive got exh heat wrap ready and waiting,.....will be buying a turbo beanie/bag, and they also sell the acl heat shield next door
    so all relevent items will be shielded
    blake
    Quote Originally Posted by shinybluesteel
    so screamer is the go.....
    yeah, MUFFLED screamer is definately the way to go i would say, something to take the exhaust leak sound away, try it with no muffler first, then quieten or louden as you see necassary.
    that turbosmart guide is a good one, here is a better version of my text description from that PDF
    (stupid imageshack isnt working and file is too big to attatch so ill put it in later)
    EDIT:
    its working again, so here is the pic
    www.vicdrift.com
    sick!.....im hoping to maybe start it tonight...hear it running for the first time in a couple weeks. lol!!!
  1. Turbo Dump Design (Split wastegate vs Not)
    Last Post: 11-02-2009, 01:47 PM
  2. Turbo Mounting Positions, ???
    Last Post: 22-11-2006, 11:55 AM
  3. Swapping wastegate actuators...
    By mullett in forum Tech and Conversions
    Last Post: 28-07-2006, 10:21 AM
