Results 16 to 21 of 21
Thread: ok...now next stage, EXT WASTEGATE MOUNTING POSITIONS?
    Default Re: ok...now next stage, EXT WASTEGATE MOUNTING POSITIONS?
    having a look at your "basic" layout, I can make one suggestion... in another thread recently, the advantages of joining up the wastegate to the rest of the exhaust further down the dump pipe was discussed... at least 30cm as the recommended length.
    So maybe weld in a low-angle joib near the end of your dump pipe.
    I'm personally against screamers on street cars, due to the illegal-ness
    well now looking at the diagram, mine is on a 90 angle,...but due to room,,,i had no other choice lol
    cheers for the info on the screamer pipes too, ^^^^^^^
    Quote Originally Posted by Draven
    are they still illegal if you run it thru say,.. a small bike muffler? (or is that then not a screamer? )
    for the angle, could you put in say, 2" of 45degree pipe in there? just to lessen the angle a little?
    the reason that they are illegal as they dont pass thru the cat converter,,,,,
    I think it would fail on two counts Stu, once for not exiting past the last opening, and once for not having a cat to control emissions. I think the noise is just another problem to deal with.
    just had a look at some of the 'ebay' style external wastegate manifiolds....,.....
    some of them make the gas do a full 180' degree bend,
    so i think i should be fine with the way ive got it,...ive got a couple of pics on the camera fone.....
    its all welded up now, and looks sweet resting in the car
  1. Turbo Dump Design (Split wastegate vs Not)
    Last Post: 11-02-2009, 01:47 PM
  2. Turbo Mounting Positions, ???
    Last Post: 22-11-2006, 11:55 AM
  3. Swapping wastegate actuators...
    By mullett in forum Tech and Conversions
    Last Post: 28-07-2006, 10:21 AM
