Results 16 to 30 of 43
Thread: AE86 Race Car Engine Options?
    Default Re: AE86 Race Car Engine Options?
    Quote Originally Posted by Mr Revhead
    same for the 1uz, unless you want to chop ya firewall they sit too high and forward for a track car.
    You mean like this one? ->
    http://members.westnet.com.au/sprintertrd/
    Not too tall, no cutting needed.
    But yes, a tad nose-heavy. Though any understeer is only a throttle-push away from being eliminated.
    what did the 2z come out in?
    Maybe an even better idea (cheaper by a mile id imagine) is go the 2.7L vvti hilux motor?? no idea on its callsign...
    Cleveland QLD
    Quote Originally Posted by Jonny Rochester
    In this age of motor swaps, I think original motors have more appeal, plus I don't want to see another AE86 cut and modifyed too much. If I was to come across to your car at a hill climb/drift event and saw you had the bonnet open, what would really light up my eyes? It would be that same 16v 4A-GE, 100% AE86, only rebuilt with big cams ~290-300deg, adjustable cam gears, quad throttles off a 20v if you want, tuned length extractors etc. Then a 2 way LSD and driven with conviction using all of the rpms. That's what I want to see.
    I went with a 20 valve, takes a bit more sorting out. It's a good one if you don't want to rebuild right away.
    I can't agree more. There have been to many AE86 cut up. That combo is exactly what I am in the middle of now.
    New Zealand
    iv worked for toyota for over 3 years.... ill never own a camry V6, ill leave it at that
    the car my mates building is a dedicated track car, original plan was for a 1uz but after trial fitting he decided it wouldnt fit in a good enough position to make it worth while.
    so he sourced a 2nd hand formula atlantic engine from a ex atlantic mechanic over here in NZ. theres also an ex hasselgren tech here hes been talking to so he has all the info he needs! just waiting on some bits iv ordered and itll be built next year.
    it all go in into a levin hatch with the TRD N2 kit. very nice
    itll go nicely with his tarmac spec ae86. and his 3-4 other ae86s in various states of condition!
    Junior Member Backyard Mechanic 1jzracing's Avatar
    i recon a 1ggze would be ideal for drifting as its relatively small in size, a supercharger and 6cyl would have tones of torque and 6's sound cool when they rev hard too
    a fool remains undescovered untill he speaks!
    86 slut Grease Monkey
    glenmore park 2745
    smallport 16v with head work bigger cams if your are on a budget
    7age if you have more money than sence
    i have no sence
    go with the smallport engine and keep it simple
    it is usually the best option
    geeez! so many replies! thanks heaps for the help guys, but like whats been mentioned, we're looking at keeping the car relatively standard in form? so deffinately a 4age motor! and after doing some read ups, looks like the 4agze is the go with added power from the s/c...
    next step is to find a motor good for a strip down and race build up?
    has anyone built a motor like this for the track and track alone?
    thanks heaps for those who replied!
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    The 4AGE in my AE82 has 250k on it and still going strong (previous owner was a lady)
    Not sure what a 400k motor would be like.
    Whats the 7AGE from?
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Quote Originally Posted by Robbos_Toyotas
    Current model Corolla Sportivo's and Celica's.
    Quote Originally Posted by strat
    ...but iv been thinking if yo wana go atmo wat about a RAV 4 motor i think they are 3S and they have VVTI so it would be revvy as big power ban good for slide. just a thought.
    The early ones are a 3SFE I think, and the later model and current ones are the 2AZFE, same as the Camry.
    The Camry V6 1MZFE looks like a good motor to me. All alloy, lightweight alloy pistons, lightweight rods, forged crank, 6 bolt mains...
    Quote Originally Posted by d-master
    7age is a hybrid motor. It is the combo of 4age head with 7afe bottom end. The 7a is in newer Corollas.
    See the threads below for more info, found from the search
    http://toymods.net/forums/search.php?searchid=194957
    check;
    http://toymods.net/forums/showthread...highlight=7age
    and
    There is more info out there, if you want to do it.
    Junior Member Domestic Engineer Sprinterboy's Avatar
    http://hachiroku.com.au/forums/viewtopic.php?t=347
    ^^^^^^^^^ AE86 with a BEAMS 3S ^^^^^
    My 86 is 4AGZE hilclimb car, easy enough
    SprinterBoyAus on YouTube
    SprinterBoyAus on Facebook
    Sorry I don't see what class you wish to run in.
    Sport sedans? U2L sports sedans? Standard? IPRA? A bit of fun at the supersprints?
    What is allowed for each class is totally different.
    You might want to grab the CAMS rule book, pick a class and get back to us. Also see what's at the pointy end of the field - gives you an idea of what's required.
    id go 4agze block and internels (it has forged internals) and a 20v head with the quad throttle bodies of course. this is primary setup i think anyway. i suggest following the TRD setups
    Quote Originally Posted by ae86_4life
    any particular reasoning to back that up?
    are you talking forced induction or NA?
    yea i'd agree with OC...
    find out what you need, then go from there... definitely the 4A-G(Z,T)E is the easiest and greatest return you can get, simply because of the power, durability and balance you can achieve with just an engine swap.. any other motor would require a lot of work to get balanced and counter-weighed (corner weighed?).. to be race-ready and competitive.. to each his own and it all comes down to what you want out of the car.. plus 4A-GE makes a really sweet induction sound and is very easily tuned for track, drift and hill-climb.. IMO a 7A is a better alternative to stroking the 4A if that's what you're after.. but from what i gather, the 4A-GE and GZE is very competitive, with each driver having a preference.. this has been covered lots of times before so a bit of searching should help u decide or persuade you further with your choice
    Last Post: 12-07-2019, 05:11 PM
  2. Engine Conversion AL25 Tercel -> 4AGE
    By Starfire in forum Engine & Driveline Conversions
    Last Post: 01-06-2008, 10:17 PM
  3. Another (easy) AE86 twin core radiator option
    By parrot in forum Tech and Conversions
    Last Post: 25-09-2007, 11:59 AM
  4. MA70 --> JZA70 Conversion
  5. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
