well I just got a stereo plug then. How do I know if the jack is mono or stereo?
AFAIK the MT doesn't take any additional inputs other than what it needs to run the engine but I will check.
Don't know if this helps with the previous questions but
In terms of filtering the knock signal, I use one high pass scientific filter at 4800 Hz, one low pass scientific filter at 12.4kHz, and a scientific band block filter from 6.2kHz to 9.6kHz, all with 66 (whatever the unit in Audition is) roll off (max). Although the primary knock frequency for EJ205 engine's 92mm bore is centered around 5.68 kHz, my experience says it ranges from about 5-6 kHz in its entirety. What I believe to be a first order harmonic (correct me if I'm wrong) is very noticeable from about 10-12 kHz.
I think I will just suck it and see. Worst case is a dead $100 laptop
