Results 1 to 7 of 7
Thread: Bar to Cable For RA23
    Junior Member 1st year Apprentice DORIGTRA23's Avatar
    south australia
    Wink Bar to Cable For RA23
    Howdy,
    Dont know if any ones already covered this i searched but could not find. So here goes please excuse the dodgeyness I still need to tidy it up a bit so the parts you will need are as follows:
    1> Pedal you can use your orig. one.
    2> KE30 Corolla pedal arm - Have to massage a bit but will bolt up to standard holes.
    3>RT/ST corona cable (sorry cant remember which one)- Too long but does the job.
    4>A Bracket for the throttle adj. - I made my own
    5>Carbie Linkage - I got mine of the old KE30 carbie but not sure if it was orig. one.
    First thing to do is mount the pedal arm and drill holes for bolts to hold cable thru fire wall (RE: Pics 1 & 2)
    Then make a bracket for the bar to run thru and cut down the orig bar setup and put a linkage over bar and its time to workout the rotation for the throttle, mount the bar bracket to bar to hold steady and then have a play working out where to have the linkage for fullon fulloff throttle is and run it around the strut top (RE: Pic 3) mount it to the mounting bracket off strut top to work out how much the cable pulls RE: Pics (5) so its placed right to get full throttle but not to much so it stays on once you have these 2 synchronised you can tack the linkage into place and remove to weld properly i also filed 2 sides flat on bar so i could use a split pin and washers to keep it tight (RE: Pic 4)
    Replace and connect everything back together heres the not so fun part you now have to get down in the footwell and bend/massage (i used vice grips) the pedal arm for allon and alloff throttle once this is done thats it only took me 1/2 a day to do this and it works perfectly.
    Hope This Helps Someone
    Cheers Clint
    (\_ _/)
    (")_(")TEAM TOUGE EST.2005
    18RG RA23
    3TC KE30 (DORI BEATER)
    CA18DET S13 (BEATEN LIKE THE BASTARD NISSAN IT IS)(MATES CAR)
    Default Re: Bar to Cable For RA23
    OI, I already posted one of these articles ages ago... :-)
    But please, rehash if you must.
    It's cool, yours has photos..
    Actually come to think of it, my article appears in the 'similar threads' bit at the bottom.
    Facebook | LinkedIn
    south australia
    STRADLATER: yours seems a lot cleaner and more thought out i was just trying to see if it would work cheers
    See STRADLATERS Thread below for more info cheers
    http://www.toymods.net/forums/showthread.php?t=4990
    Also see RODGERS
    http://www.toymods.net/forums/showthread.php?t=4064
    Thanks Guys
    (\_ _/)
    18RG RA23
    Hi Clint,
    Good option.
    Add this thread to the list for other ideas.
    Regards
    Rodger
    *SHAMELESS PLUG*
    Hehehe
    Facebook | LinkedIn
    Oh Ok.
    Shameless but informative (I think anyway). I suppose I still have not given away my secret ingredients.
    Regards
    Rodger
    Eh, it's all information transfer anyway hey..
    Facebook | LinkedIn
  1. Earth Cable getting hot
    By SilverGhost in forum Tech and Conversions
    Last Post: 26-10-2006, 09:03 PM
  2. How to fix your Jumpy Speedometer
    Last Post: 13-10-2006, 06:58 PM
  3. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
  4. ra23/ra28 linkage to cable for 18rgu
    By krohla-10 in forum Tech and Conversions
    Last Post: 29-03-2006, 12:45 PM
