Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Tightening the harmonic balancer bolt on JZ's
    Default Tightening the harmonic balancer bolt on JZ's
    What are some easy and safe ways of stopping the engine from turning over besides an SST in an auto. I want to make sure its done up tight enough so that it doesn't come loose and destroy the crank.
    Default Re: Tightening the harmonic balancer bolt on JZ's
    rattle gun
    failing that put it in gear and chock the wheels and have hte handbrake on and use a big bar.
    clutch will slip at some point, but by that stage im sure it will be tight enough to not come undone.
    the engine spins in the do it up direction anyway...
    Its an auto.
    bah, i read that and didnt click...
    rattle gun?
    im not sure how auto boxes work (never touched the icky things) but what happens if you put it in gear with brake on?
    or in park?
    I used a rattle gut to do it up. But you would need a massive one to do it tight enough. You can't stop the engine turning with an auto if you put it in gear/park.
    Anyone made their own SST?
    Penrith BC
    large block of wood under #1 crank counterweight wedge into side of block
    easy
    ../delete/ban
    tech moderator
    not much good the engine is still complete and in the car
    id be looking at making an sst that bolts onto the front crank pulley like a two prong pin spanner with a pair of very high tensile bolts screwing into the pulley. then have a nice long bar and an assistant holding the crank in place whilst you hit it with a torque wrench and do it up.
    Quote Originally Posted by 2JZR31
    I made this for my 7mge when I changed the timing belt.
    yup there we go thats exactly what i was thinking of
    I screwed the torque wrench... I just put a breaker bar on it and hit it with a baby sledge till it wouldn't turn no more.
    I figured I wasn't really going to get it tightened up to factory specs anyhow.
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    I used a rattle gun - lasted 20,000kms+ with no problems..
    Western Aus
    auto should stop the engine turning if its in park dude.
    i know mine did...?
    Eldar.O.
    In front of the flex plate there is a cover you can remove to undo the screws which hold on the torque converter. Take it off and put a piece of steel, wood etc between one of the screws and the housing .When you do the engine will not turn , Worked for me.
    Jealousy is a curse
    i know mine did...?
    So how come you can start the engine when it's in park?
  1. harmonic balancer blues
    By SIKPUPY in forum Tech and Conversions
    Last Post: 15-05-2007, 09:41 PM
  2. Help with 2VZ engine. harmoic balancer Off and sump ON
    Last Post: 11-12-2006, 09:27 AM
  3. removing the harmonic balancer on 1jz
    By soarerchic in forum Tech and Conversions
    Last Post: 16-10-2006, 12:21 AM
  4. harmonic balancer ??? !!!!!
    By 1jzracing in forum Tech and Conversions
    Last Post: 04-04-2006, 01:30 PM
