The GZE manifold is a pretty bad design, but they did that due to packaging constraints. Once you've got the intake pipe, throttle, blower, cooler pipes, etc in there, not much room is free to run a proper inlet manifold.
So yes, you can use an NA AE92 inlet manifold on a GZE (it all bolts up fine if you have a smallport head) you'll need to do lots of custom work to make everything else fit. Off the top of my head this would include:
- New SC top mount (usually mounts to the manifold)
- lean SC over to clear manifold
- New throttle -> SC piping
- New SC -> IC piping
- Blank off throttle from end of manifold
- Ensure the whole shooting match fits between block and firewall. It could well foul on something once you lean the SC to clear the mani.
Basically not worth the effort unless you are up for a big project.
Hen
PS, as for quads, most of the above applies, but then you need to consider you are moving throttle from pre-SC to post-SC aswell.
