Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Help needed with 1UZ: Brisbane
    Worlds Fastest 1G Backyard Mechanic
    Default Help needed with 1UZ: Brisbane
    Hey guys, I am in the process of building a street car to go with my Panlevan, maybe even use it as a tow car for the drags. Have purchased the vehicle, which prob much to many of your disgust is a series 3 RX7, but on the plus(and toyota) side, I am fitting a 1UZ V8 engine, along with auto, borg warner diff, 31 spline billet axles, etc etc, the car will be turbocharged with a T72 turbo and producing around 500rwhp on the stock bottom end and low boost for now.
    Now, my question for help. Does anyone in brisbane have either a stuffed engine, or a block and heads, that I can come and borrow for a few hours to drop into the engine bay to check clearance?? The bay is def long and wide enough, but I'm slightly concerned about the steering rack and how close it will be to the exhaust manifold or corner of the head, just from some basic measurements I took.
    I am happy to give someone some $$ for the privledge, but I really need to borrow it in teh next day or 3, as I would like to purchase the engine before christmas so I can install it over the break. Any help would be greatly appreciated. Feel free to pm me, or sms me on 0410 730 598, and I'm a good person to owe you a favour in the future
    6BOOST
    Dreamer Backyard Mechanic millsi's Avatar
    Default Re: Help needed with 1UZ: Brisbane
    try scott at venom customs
    32083224
    I've got a couple of spares at home, but I won't be home until about the 1st or so of next month sorry.
    What Panelvan is it?
    QCA probably can sell you mounts to bolt it in.
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    He is putting a 1UZ into an rx7. The panelvan he speaks of is the 9 second ke70 van.
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
    Oh, whoops, misread.
    Wouldn't surprise me if QCA had already done a couple of RX7's.
    Its worth a try.
    Thanks for all the input guys, I bought an engine today, I knew it was going to be close, but I just bit the bullet, besides which only paid $950 for an engine with warrantee, so I'm happy. I've done somemore accurate measurements, and while its tight, I think I'll have about 10mm of clearance from the exhaust manifold to the steering box on the drivers side, that was the only single clearance issue. I do however have to fark about with a sump, the engine came with a front sump, which doesn't even go close to being usable, but I picked up a rear sump for $350 as well. I thought this was a bit dear, but he said if I don't need it or come across another he'll give me the $$ back.
    Now need to investigate brake upgrades for the series 1/2/3 RX7 so I get 4 spots and 5 stud toyota/ford pattern, no one seems to know of any upgrades.
    6BOOST
    And who's QCA??
    6BOOST
    QCA is QuadCams Australia, based in Warwick QLD.
    Not sure on his contact details.
    I just PM him on the Lextreme forums.
    Junior Member Grease Monkey Jasper's Avatar
    Quad Cams Australia
    60 Albion St Warwick 4370
    (07) 4661 4551
    Haha, weird, I grew up in Warwick
    I just wanted to publicly thank Jasper for putting me onot Peter at Quadcams Australia. He is one of the nicest people I have ever dealt with, he gave me a free bell housing and fuel rails and ordered all my timing belt and water pump stuff in, and even met me on boxing day to pick it all up. A true enthusiest in it for the pleasure of helping customers rather than a quick $$.
    Cheers........................Kyle
    CrUZida put you onto him!
    But you're welcome.
    Quote Originally Posted by 6BOOST
    6BOOST
    You aren't looking hard enough S4/5/6 all share the 5-stud toyota/ford stud pattern, and the turbo ones come with biggish 4-spots, there are kits out there to do the conversion.
    Junior Member Backyard Mechanic 71RA20's Avatar
    California
    Heres a PDF of engine and some other measurments.
    http://www.lextreme.com/Lex%20Soarer92.pdf
    1. these are approximate only +/- 5mm
    2. based on front-mount sump 1UZ, that is why I have taken measurements for the front using the crank centreline for a datum, and the side using the mount plate centreline as a datum.
    This means all dimensions are applicable to most 1UZ variants, except of course for specific sump details.
    I strongly suggest that you source a front of engine photo and side photos from the forums so you can make sense of the dimensions.
    3. intended as a guide only- you should go to a wrecker/engine supplier and suss-out the whole thing before placing your order!
    FRONT OF ENGINE
    datum is centreline of crankshaft, with dimensions North/East/South/West of this point;
    u'side of sump S 240
    rh side of sump W 220
    lh side of sump E 200
    sides of heads E/W 335 (+50 for exhaust manifold)
    top of heads N 370
    u'side of alternator S 95
    rh side of alternator W 290
    u'side of p.steer pump N 20
    rh side of p.steer pump W 360
    u'side p.steer reservoir N 135
    rh side p.steer reservoir W 375
    top p.steer reservoir N 320
    top inlet manifold N 450
    LH SIDE OF ENGINE
    datum is centre of engine block mount plate (not actual engine mount), with dimensions North/East/South/West of this point;
    [Note that the datum is on the same horizontal plane as the crankshaft]
    front of engine W 345
    rear of engine E 310
    front of sump W 260
    rear of sump W 15
    sump drain tray clearance S 175
    centreline exhaust manifold outlet E 340
    u'side of exhaust manifold outlet flanges S 75
    RH SIDE OF ENGINE
    same datum as above;
    rear of alternator E 120
    rear p.steer pump E 150
    front p.steer reservoir E 290
    rear p.steer reservoir E 200
    OTHER USEFUL MEASUREMENTS
    Centreline of crank to side of exhaust manifold outlet flange 310mm
    An Eye for an Eye would leave the world Blind
    Last Post: 29-10-2021, 09:49 AM
  2. Pics needed: 1uz oil filter / air con fittement
    Last Post: 11-09-2006, 02:48 PM
  3. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
