this is more common than you would think
check your timing tensioner for side movement also check your water pump bearing
what happens is the water pump gear or tensioner pulley bearing will wear causing the timing belt to try to run off the pulleys and eat into the cover
have seen this on many 1hz timing belts too not same motor but same principle but it wears the belt away on the cover
i have pulled belts off that have been 20mm wide and still running on a 1hz and when they snap its not pretty
