Results 1 to 14 of 14
Thread: ZE piston weight
    Default ZE piston weight
    Just got thinking after this post that a set of late ZE pistons and a shaved head could be a nice, economical basis for a good NA motor..
    I don't suppose anyone knows what the late ZE pistons weight in at?
    S.A
    Default Re: ZE piston weight
    No... I dont think anyone has weighed them yet. There was a thread about piston weights not long ago. There were a few pistons with there weights recorded but no GZE.
    I have some too weigh but dont have the scales to do it!
    Quote Originally Posted by 30psi 4agte
    I've got both, but they're about 6,000km from me at the moment.
    They're quite a bit heavier than regular GE pistons though Isuspect, being forged.
    why do you want such low compression?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Quote Originally Posted by Billzilla
    I seem to recall the pistons from my ZE weren't that heavy, but didn't think to weight them. Unfortunately, they are in a car now
    Quote Originally Posted by shinybluesteel
    If you mill the head, you can get around 11:1 from a 9:1 piston.
    ah ok, thats where i thought you were going, but the thread you mentioned only showed around 9.4:1 as the "new" CR.
    mind the squish areas!
    www.vicdrift.com
    That's with 0.023" taken off, if you take off 0.050" off you get a heap more squish area:
    umm, i weighed them.. they were late model GZE pistons...
    i'll try to find thread later
    piston weight for GZE AE92 0.5mm oversize
    about 305grams
    pin weight = 100grams
    total, about 405 grams
    the pins are also 4mm wall thickness...
    Not that you need it but "You must spread some Reputation around before giving it to oldcorollas again."
    Thanks - That's 5g less than the weight of the silvertop 20v pistons I've got in the shed...
    they are 310 or 410 total? goddamn, i thought the GZE slugs were heavy buggers!!
    I just checked again:
    There might be a couple of grams of oil in there and it's standard size, but the weight is close.
    Just found this thread on club4ag. It looks like the blacktop pistons are heavier than the silvertop ones! I didn't expect that - particularly with the thinner rods...
  1. Buying some new piston rings
    Last Post: 11-11-2006, 10:41 AM
  2. weight distribution
    By mikie in forum Tech and Conversions
    Last Post: 05-08-2006, 09:16 PM
  3. WTF? Deposits in piston....
    By mullett in forum Tech and Conversions
    Last Post: 08-07-2006, 09:06 PM
