Page 2 of 12 FirstFirst 1234 ... LastLast
Results 16 to 30 of 178
Thread: Hilux front brakes
    Default Re: Hilux front brakes
    ... know if the Hilux caliper brackets are a bolt-on type, or if they are welded/cast to the hub/spindle.
    I'll check for you tonight.
    Peter
    Quote Originally Posted by -==L=a=N=c=E==-
    i'd rep you again, but i've already repped you infotechplus. Great info!
    What size wheel would you need? does the stock 14" still slip over or not?
    What of brake lines as well?
    I'm running Work 17 x 7s but they are overkill. I can't say for sure but the 14" might be too small. Other factors might influence that answer.
    I've rebuilt my R32 calipers and checked the spacing but haven't got to actually bolting them on yet - too busy with the 1G-GZE conversion. I've also had the R32 rotors machined in anticipation. But I know two people who have R32 combos on their Luxes and they work beautifully.
    I think it's a very affordable upgrade for the Lux especially with the engine upgrade. I'll mock up the R32 combo tonight when I get home and take some snaps.
    I'm pretty sure Sideshow has R32s on his Lux as well.
    Peter
    Dreamer Backyard Mechanic millsi's Avatar
    whats a fair price to pay for fair condition r32 gtr calipers.
    and how much for rebuild kits?
    What rotor diameter do you end up with when you run the R32 caliper on the Hilux?
    My mate is looking into a brake upgrade for his 1GGTE hilux so this info is very much appreciated
    Quote Originally Posted by millsi
    Are you talking about the Nissan calipers or the Brembo ones that come on the V-Spec R32 GTR??
    I think one of the sponsors on this forum CVAP sells the nissan calipers for about $300 a pair with all the clips and pins etc. The Brembos would be much more.
    The rebuild kit I got was genuine Nissan - about $120 from memory.
    The caliper/rotor set (2 x calipers, 2 x rotors) about $250 - $350 from a used Jap importer. I saw a set on Ebay for $299. SSS Automotive, JustJap, etc
    Peter
    You can get a generic rebuild kit for these calipers for $30 from Repco for an axle set.
    there are calipers (no discs) on ebay atm for $300. a bit steep i think!
    Bugger!
    What do you get Takai? I got seals, rubbers, O-rings, clips and lube for each piston in the Nissan set. I got them through the same place as I got the calipers and rotors (SSS Automotive).
    Regards,
    Peter
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    Quote Originally Posted by infotechplus
    Peter
    Well i have 15's on my front wheels, and they are Convo Pro's.
    I'm hoping because the wheel is naturally spaced out a fair bit, it shouldn't make squat difference.
    Might have to borrow a set of calipers off a mate and test fit it, see if it'll go.
    I definately need more stopping power, with the amount of grunt i'm about to get
    These are on Oz EBAY for $299 Buy Now plus Postage
    Peter
    Rosewood
    so, is it the caliper that needs to be shifter 20mm or the rotor?
    EDIT: also do you have a picture of the setup dummy mounted?
    Peter, I don't know if you saw my question earlier but can you just confirm for me that in purchasing the above package and following your setup explained earlier the only machining to the disc is for the centre hole and no machining of the disc diameter is required?
    Cheers.
    The caliper.
    Pics coming.
    Peter
    Cheers.
    My information from one of the guys that has done this setup is that
    1. The stud pattern is okay for the rotor
    2. The rotor centre has to be machined a little to allow it to slip over the Hilux axle
    3. A 20mm spacer machined to centre the caliper over the disc
    4. Longer bolts to fit through the caliper, spacer and Hilux hub
    That's it.
    But to be 100% sure I will confirm this info.
    Peter
    Rosewood
    is it spaced further towards the wheel, or further away?
    could you use rotors with deeper hats to offset them?
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  3. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
