Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 106 to 120 of 178
Thread: Hilux front brakes
  1. #106
    Default Re: Hilux front brakes
    Quote Originally Posted by SL666
    erm, YN57 SR5 doesn't need commercially rated tyres... only the NON SR5 ones have it.
    You may be right, but what evidence do I have. Everyone for the past 25yrs has told me I need 103 load rated tyres.
    I'd love to be able to show them otherwise and tell them to stick 103 up their arse & that my performace passenger tyres are legit.
  2. #107
    here's the original brochure - notice the 185 SR 14's for the SR5 models.
    and speaking of brakes, something to be aware of, the SR5's ran different brakes to the other hiluxes - useful stuff to know when you are replacing the slave cyl's etc
    also notice that the GVM is 500kg lower for the SR5
  3. #108
    So what's the load rating of 185SR14?
    I've done a quick search, nothing shows about their load rating.
    Has anyone still got an original tyre spec plackard
    (and apologies for the hijack)
  4. #109
    well according to this page http://www.bridgestone.com.au/tyres/...e/markings.asp the S speed rating (180km/h - pretty optimistic for a stock hilux) and based on the GVM (2050 for a SR5) i would assume it would require a load index of 85 (a 515kg/tire) - if thats the way it works...
  5. #110
    Your rear axle rating @ 300kgs lighter then my RN85R and my required load rating is ment to be 104/105. The GVM on yours is also @600kgs lighter. You should be able to get your tyre shop to tell you your load rating if you give them your GVM. Just don't tell them its a Hilux's GVM.
  6. #111
    I just looked up master cylinder sizes in the Australian Truck and Auto Parts catalogue and it lists the MA70 and Hilux as the same size, 25.4mm. The Nissan Skyline R32 isn't listed but all other Skylines (R30 & 31) are only 22.5mm. So for those that were/are doing this front brake conversion or the rear disc brake conversion, I can't see that there is any point in changing the MC.
  7. #112
    A litle more info. The original dunlops had 1360lb max load rating. Tyre rating will always exceed the GVM by some margin. So it's more likely to be 90~92ish. But it still doesn't really help when pulled up for a vehicle inspection.
  8. #113
    1jlux: the SR5 mast cyl is a different bore too.. (but it doesn't make any difference - im now using a 'normal' hilux one)
    greybeard: at least you can argue the point with them.. get them to look it up.. alternative being that we find a pic of a tyre plackard (or fake one) get it made up and stick it on.
  9. #114
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    When you find one of these "Tyre Placards" that your going to stick on.. let me know.
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  10. #115
    Quote Originally Posted by 1JZ~lux
    The Spacers before drilling
    The spacers after drilling
    Can you post up the L x W x H of that spacer and the material you used. that would be much appreciated. Or better still, are you in a position to make up some more? I would cover costs and postage if so.
    Peter
  11. #116
    Rosewood
    if these end up working on a late model lux, i'd be interested!
    I just want to see if i'll have enough clearance using my 15" wheels. I need bigger brakes, bit hard to slow down these days.... hahaha
  12. #117
    The spacer's started as a single piece of 75x??x130?? steel. It was a uncommon thickness so was hard to find without needing to be ordered. It was cut down the center to give 2 pieces 30mm wide at the shop I got it from which was difficult to do (saw wasn't a big enough blade). It was then taken to a backyard mechanic who milled it down to 30??x20x130??. I will measure the length and width tomorrow and post the exact measurements.
    After Easter I'll get the broken bolt out of the caliper and finish this upgrade. Then I'll do the MA70 rear disc conversion and take it to a brake shop to get the bias set right.
  13. #118
    Rosewood
    just adjust the brake bias with the load sensing valve. it is quite straight forward.
  14. #119
    I was going to remove the load sensing when I do the suspension 'cause it'll be applying the bakes all the time when I lower the truck.
  15. #120
    Any updates? I'm up to this stage on my conversion
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  3. Replies: 4
    Last Post: 08-09-2005, 01:17 PM
