Results 16 to 20 of 20
Thread: What flywheels fit inside a rwd 4a bellhousing
    AB
    Default Re: What flywheels fit inside a rwd 4a bellhousing
    OK I am wrong. Not all flywheels will fit in a T50. The only point i am trying to make here is that the flywheel off of early bigport 4age is slightly smaller(in diameter) than all the rest. if nothing else will fit for goldta22, he should source one. if he is using the larger 225mm then chances are he can just use any 200/212mm.
    Now that we got the flywheel issue sorted can anyone recommend a good clutch to go with a 4agze? I'm running stock 4age clutch with 200mm flywheel at the moment. Will the exedy heavy duty do the job?
    Thanks
    All 4AC and 4AF (and i assume 7AF) flywheels will fit inside the T50 bellhousing. They are all 200mm 6bolt flywheels.
    ALL 4A T50 bellhousings are the same size. The only difference between the 4A-GE and 4A-C housings is the location of the clutch slave. GE is on the drivers side away from the exhaust, and the 4AC is on the passenger side for the same reason.
    Tom: i suggest that you start a new thread for clutches, this one is regarding flywheel sizes and so you wont get any real response in here.
    Quote Originally Posted by Tom86
    Thanks
    the exedy heaveyduty clutch kit is good. i use one in the feral with the 4agte, the organic clutch plate takes HEAPS of abuse and has done for just over 3 years now.
    http://www.exedy.com.au/catalogue-de...sp?id=39000611
    From my personal experience psychofox has it nailed
  1. A-series bellhousing to OLD T-series transmission
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 21-06-2008, 04:24 PM
  2. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 04:58 PM
  3. 4A-GZE Flywheels.
    By mullett in forum Tech and Conversions
    Last Post: 30-04-2006, 11:17 PM
