Results 16 to 19 of 19
Thread: LED light wiring
    Default Re: LED light wiring
    One point to note here, however, is that LED indicators are actually illegal to use on the street - ADRs prohibit their use. I should know, I import the damn things.
    Would be a fun project still, so why not give it a go anyway? The parts are worth next to nicks.
    umm, seen the back of a 3 series BMW lately?
    Or a truck?
    How can an ADR prohibit their use? The only thing I can see being the problem is that an LED doesn't throw the light through the same arc that an incandescant globe does, but that's mainly for the higher wattage ones, like 25W or so.
    BMWs and trucks can get away with it, because being a mass produced vehicle they vehicle as a whole is assessed for ADR compliance.
    Thus the car is ADR compliant as it is made from the factory.
    When you are modifying a car, you are bound by the individual ADRs for each modification - which often dont match with what you see on factory produced vehicles.
    Take the wing mirror indicators on Mercs for example. Check out the ADRs on that!
    ...... butt scratcher?!
    User Conversion King
    NWA
    something to note here river,
    youll only need to have one 555 timer if you decide to go with that route. the factory wiring (for old toyotas at least) is
    ____________________________-RH stalk switch - RH indicator circuit
    batt +12v -> fuse -> flasher unit -> |- hazard switch < ...............................> ground
    ____________________________-LH stalk switch - LH indicator circuit
    messy and all!
    so find the 2 wires that connect to the flasher and insert the 555 there
    something intersting though is that jaycar sell pre-fab'ed flashing 10mm LED's
    although you might have troubles if they start to flash out of sync after a while.
    hello
    Thanks. Using one 555 circuit is better, and you can chuck out the bokka!!!!
    seeyuzz
    river
  1. Alternator Wiring 4AGE -> Ke30 Loom Solved
    Last Post: 11-09-2006, 08:09 PM
  2. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  3. ST162 warning light?!?!
    By XiL3D in forum Tech and Conversions
    Last Post: 08-03-2006, 02:03 PM
  4. Replies: 0
    Last Post: 07-02-2006, 12:01 PM
  5. Alternator Warning Light Wiring
    Last Post: 04-01-2006, 09:32 PM
