pretty easy to do this.
You obviously will be needing a switch and a fuse holder, with a fuse for either each or both lights together.
You'll need a wire from probably ACC(accessories power=when wire is tested it has 12v when key turned to ACC) fused at a rating of both light amperage.
Generally 15A will be fine depending on the lights.
Then to the switch through to the 12v+ve on the lights.
Then you need to find a good clean earthing bolt, get some crimp on connectors that can be bolted down and crimp/solder them on the 12-ve wires.
Pretty easy.
the neon on my side napped in half. Ohwell off to get another one and find a proper secure place for it this time.... atleast now i know how it all hooks up. Cheers for the help guys, cuzzo ur a fu#@n lifesaver.
