MOS I'm using my tacho for RPM readings. I've tapped in to the IG- feed to the diagnostics port on the inlet manifold that is fed the pulses from the ignitor. I've built a little circuit to amplify this and am feeding it to my BMW Tacho.
Rev limit is reached at jsut over 7000rpm as can be determined and proven by holding it in first until you reach it whilst watching the tacho. This was conclusive enough for me.
Speed sensors I have nothing more then factory fitted to the Toyota ECU< I have not interfaced any further then this.
My car is a lard arse and I believe is easily over 1500kgs. the BMW factory weight is 1540kg's. I have stereo etc on top of this so would expect to be around the 1600kg mark.
I throw no error codes when the diagnostics are entered, the check engine light just flashes on off for as long as you leave it in the mode.
Std extension housing right down to the rubber donut. I have fitted an FCD, 3inch ehxuast, custom dump to replace cast restirctor (trhis has a 3inch-2.5inch cone restrictor placed in it), back throught mandrels to a 3inch steel CAT and then through a 22inch long 3 inch resonator back to a berkley 3inch in twin 2.5inch out opffset muffler.
