Results 16 to 30 of 36
Thread: electric ignition
    Junior Member 1st year Apprentice Mr_Toyota's Avatar
    tasmania
    Default Re: electric ignition
    ok thanks mate,
    Can the guts outta the electronic dizzy be put into the 18r dizzy without removing the dizzy?,
    Is removing the dizzy straight forward??
    thanks
    1980 RN31 Hilux, Stock 18RC with extractors!
    Here are some photos to help you identify the parts mate.
    This is from my Celica...buggered if i know if its original.
    This is from a 18RGEU.
    Rudi
    tasmania
    Thanks for that mate,
    helps alot.
    will go check out the wreckers on the weekend,
    some pics of the internals in a 18r dizzy would be handy
    Unfortunately i dont have any 18R's to take pics of...
    Rudi
    tasmania
    Was meaning of either 21r or 22re electronic guts in a 18r dizzy, just to compare for when i do mine..
    thanks heaps though mate
    ahh...my bad
    I can take some photos of the 18RGEU internals if you want man...should be fairly similar id imagine...
    Rudi
    You thought of using a Jaycar/Silicon-Chip HEI kit?
    You can use that with the standard points in the dizzy.
    Difference is youll get a much stronger spark and the points will never wear out, so no more tuning needed.
    While the Jaycar kit does reduce the amount of current going through the points (and thus reducing its wear) the rubbing block on the points will still wear on the lobes. So tuning will still be required to account for that. Although it obviously won't have to be done as often.
    Rudi
    tasmania
    ok,
    so is it only the 22RE dizzy internals that fit in the 18r dizzy, that can be run by the 21r Coil and igniter...or will the 21r dizzy internals fit aswell?
    Just saves me less hassle knowing there is a complete RA60 at the wreckers with a 21r
    thanks
    Edit, yeah man some pics would be cool, thanks!
    i think the guts of the 21r dizzy are similar, if not identical. Both have vacuum advance...
    tasmania
    ok thanks for that mate,
    Just makes it easy to buy the whole lot...
    thanks
    21R, 22R and 22RE are identical as far as the ignition is concerned. The guts are really easy to swap over, spend 10 mins pulling the dizzy apart and you will see what I mean. Some 18R dizzies wont work with the 2xR innards because the shape of where the vacuum diaphragm mounts to the advance plate is different. Make sure you have a capable 18R dizzy, otherwise you will need to get another 18R dizzy which is suitable from a wrecker. Sorry I dont have pics, but I have done this a number of times. PM me if you want to send the 2 dizzies to me and I can swap the guts over quick enough.
    The coil and igniter will look very similar to the 18RGUE one pictured (black barrel coil and silver ignitor on a common mounting bracket), except that the 2xR items dont have the ballast resistor. You will not be able to use your points coil with this setup as it will overheat.
    Junior Member Grease Monkey ra65's Avatar
    I have a 22re coil and ignitor if you want to make me an offer.
    G'Day mate,
    FInally took some pics of the 18RGU dizzy man
    And the 18RGEU
    Rudi
    tasmania
    o man ra23,
    Ill get back to you if i get stumped on ding the swapped, and thanks for the info too, big help!
    RA65, coil and igniter, hmmm going to check the wreckers later today, and ill get back to you, might have to get a 2*r dizzy off here anyway..
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. 1jz ignition
    Last Post: 04-07-2010, 08:25 PM
  3. Ignition Switch
    By rj_darlow in forum Tech and Conversions
    Last Post: 20-10-2006, 11:48 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
  5. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 12:29 AM
