Results 16 to 23 of 23
Thread: What is the best oil to use in a stock MA61 diff?
    Default Re: What is the best oil to use in a stock MA61 diff?
    Okay, i got mixed up on what the problem that i have is. I blame that on my dad he called it axel tramp
    So yes i get chattering when taking tight corners at low speed sometimes, thats my problem. I'll have to go out and buy some Penrite Limslip.
    Axle tramp is the axles physically bouncing up and down and losing contact with the road.
    Chattering can be because of the wrong fluid, but it also can be because the LSD is fucked, as was the case with my old one.
    Thanks for explaining that one to me Cruzida, im now not so confused
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    I've always run Penrite limslip with no issues.
    I high doubt the axle tramp is diff related. More likely to be spring/shock related.
    I'm going to be running Penrites new SIN diff oil in my truetrac.
    But at $50 for 2.5L, its not cheap.
    Hang on... With the TruTrac LSD, you use standard diff oil? If not, bugger... down goes the diff for another refill of LSD oil. I got told to run standard diff oil for TruTrac LSDs...
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
    TruTrac you can run either.
    There aren't many hypo oils out there that are designed for non-lsd.
    the truetrac is designed to run on the same oil designed for the stock diff.
    Of course, you put a high quality diff in, and it's generally a good idea to put a high quality oil in... Penrite SIN, Elf, and Redline all make diff oil suitable for the ma61 stock diff (and truetrac), and are also top quality products (and very exxy)
    Changed the oil over to Penrite Limslip today and havn't had any chatter today at all. So all is looking good. But there was a nice mm or 2 of metal shavings on the plug when i took it out and the oil had already gone a dark brown colour from a nearly clear colour in like 4 days. I thought that was a bit odd.
    On a side note, I thought as CrUZida said, the Truetrac doesn't *require* LSD oil persay, but most of the decent oils are.
    Must keep track of how the Sin performs, my car has only seen 5000km or so, and is already pouring oil out the breather That or I should drive it more gently....nah.
  1. The old "volvo diff into celica conversion"
    By Toy77 in forum Tech and Conversions
    Last Post: 08-09-2016, 06:30 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 04:40 PM
  5. BMW E36 diff choice? 300zx - Supra
    By 2J-BMW in forum Tech and Conversions
    Last Post: 23-12-2005, 09:49 PM
