hi guys,
1ggte gen3 question
i have two wires which i cant find pinouts for on my gx81 body plug
no.15 is violet with green trace
no.11 is black
anyone happen to know what theyre for?
8,9,10 and 14 matched the wiring diagrams, so i have sorted them out
EDIT: upon closer inspection, i think i need the ECT section of the wiring diagram for a 1ggte gen 3. Already have the EFI section but it does not have the pinouts for 11 and 15. my 1jzgte wiring diagram had EFI and ECT section so i could check all pins
thanks
hi guys
1g gte ta28 celica conversion
need 1g gte oil pan with front sump
is there anyone that can help me out here
Hi JCMO,
Ok I got a 1GGTE gen3 with manual ECU for celica conversion project which has been put on hold at the moment ... I have changed my my plans and wan stick it into a 1986 Soarer which already has a 1GGTE gen2 with auto ECU. The gen2 engine has requires the cylinder head to be repaired hence I want use the gen3 engine for the time being while I slowly rebuild the other. Regarding your above comments for Gen2 injectors and Ballast resistor being used with a gen3 engine running off a gen2 ecu and loom
Can I just pull the injectors off my dead gen2 and use them on the gen3? Also will the gen2 engine setup already have a ballast resistor I can just use with the gen3? or do I need to get an aftermarket ballast resistor? if so what brand/model do you recommend?
I am hoping I can mix and match between the two to get the gen3 running with loom and ecu from the gen2 engine..
Thanks![]()
cheers steve,
1ggte, 11.22 @122mph
i cant seem to attach the PDF files to the thread for some reason, can anyone spell it out for me ????
cheers steve,
If you go advanced reply you should be able to attach them?
If not maybe zip file?
Does this work ?????
Does'nt seem too
cheers steve,
Yea doesn't work, says file is corrupted.
A lot of these docs, pics and attachments are long dead, maybe we could revive this thread and post up the docs that we've all got squirelled away? A lot of it would be really handy for those of us doing the 1ggte conversion.
Ive got the factory manuals and have emailed them to a number of people if anyone wants them, PM me
Cheers, Andy
Hey Guys,
Didn't really know where to post this but so pardon me in advance
Was redoing my GA70 engine harness and cause I'm just one smart lil shit, I forgot to take photos of the process and thus did not know where one of the starter cable goes. The cable in question is a crimped connection.
Prior to redoing it, the ECT plug starter wires had been cut into to power a relay that went into the body harness.
Any help is appreciated. Andy still awaiting the diagrams.
Ian
