Results 46 to 60 of 73
Thread: 1G-GTE tech info/diagrams
  1. #46
    Junior Member Backyard Mechanic VasH's Avatar
    Default Re: 1G-GTE tech info/diagrams
    my gen 2 has 6 wires but not 8??
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
  2. #47
    Nov 2007
    I will get a photo of it. It's definitely the TPS.
    "Throttle Sensor - 39452-30040"
    It has 2 large yellow connectors that attach from the main loom to the throttle sensor.
    The first connector has 6 wires - Blue, Black, Green, Light Yellow, Purple, Tan
    The Second connector has two Tan wires coming out of it and going to the throttle position sensor.
  3. #48
    Jul 2009
    while we are on TPS's what should the ohms reading be at closed throttle/ idle.
    and across which pins
    btw its a gen3
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
  4. #49
    User Conversion King
    NWA
    search for the supra mk III TSRM.
    same values for nearly all the sensors on the 7m
    hello
  5. #50
    Nov 2007
    Well here are the pictures,
    Well definately it's the TPS I'm looking, counted those wires and there is 8.
    http://img694.imageshack.us/img694/6420/tps.jpg
    The above picture shows 2 connectors going to the TPS, the one on the left has 6 wires.
    The one on the right has the other 2 wires which I cant find on any wiring diagram. What are they?
    Thanks.
  6. #51
    Aug 2009
    Hey people, Just a small one, I'm doing a engine conversion 1GGEU - 1GGTE.
    My current 1GGEU body loom has a 4 pin "main EFI" relay plug but, the 1GGTE engine wiring loom has a 6 pin "main EFI" relay plug. Does anyone know what I can do. Unfortunately i cant tell what Gen my engine is or what its out of. Any Help would be greatly appreciated.
    south austraila
    Quote Originally Posted by Fisher View Post
    Hmmmm... i think the 4 pin is the main power relay & you will find that the 6 pin is the Fuel relay..
    Project: '82, GA61 XX
  8. #53
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Hey everyone, I've been trying to wire up a 1JZ my mate Jake's GZ20. But have run into a problem with the main wiring behind the glovebox. It's different to the normal body plug, it has more wires, including 3 that go across the top. I can't find the diagrams for this plug anywhere on the net.
    Here's some pics to desrcibe it better
  9. #54
    Junior Member Grease Monkey 81hilux09's Avatar
    Apr 2009
    i had that plug on my 1g engine loom for a gen 3.
    this pic is off the wiring diagrams and is pretty close to it.. the three thick wires in the middle should be blk/white, blk/blue and blk/red. on mine they were for neutral switch and the blk/red might have needed ign power.
    i couldn't find anything for a gz20 or supra for the body wiring, good luck
  10. #55
    Aug 2009
    Hey People, Just another quick one,
    Got a Gen 3 motor, but have gen 2 (yellow) injectors, will they work? I'm practically done with the build. Cheers
  11. #56
    Which computer is driving the injectors? gen 1/2 are low impedance and gen 3 are high impedance
    RA23 - Twincharged
    JZZ20 - Daily
  12. #57
    Aug 2009
    Gen 3 Computer
  13. #58
    Does anyone have the pdf's for the 1gge/1ggte available? grants links are now dead and I need some specs for clearances etc
    RA23 - Twincharged
    JZZ20 - Daily
  14. #59
    Apr 2009
  15. #60
    That my friend is fkn fantastic and + rep
    RA23 - Twincharged
    JZZ20 - Daily
  1. 1G-GTE tech info/diagrams
    Last Post: 06-01-2008, 12:00 AM
  2. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
