Results 31 to 45 of 73
Thread: 1G-GTE tech info/diagrams
    Default Re: 1G-GTE tech info/diagrams
    Does anyone have a translation of the ECU pinout acronyms?
    '77 RA28LT #2 ← 2.2L 18RG...
    Quote Originally Posted by RAd28 View Post
    Is this any help ?
    AB1,2,3,4 Supercharger Bypass Valve
    ABV Supercharger Bypass Valve VSV
    ADJ2 Ground
    A/C SW A/C Switch Signal
    A/C (1) A/C Amplifier
    ACIS Accoustic Control Intake System
    ACIS ACIS VSV
    ACMG A/C Magnetic Clutch Relay
    ACT Air Conditioning
    ACV A/C Idle Up Valve
    AF +/- Air/Fuel Ratio Sensor
    AFL +/- Air/Fuel Ratio Sensor
    AFR +/- Air/Fuel Ratio Sensor
    AMC A/C Amplifier
    (+B) Battery Power from EFI Relay
    BATT Battery Power
    B/M FR-HTR (Hi) Relay
    CF A/C Pressure Switch Relay
    CG Chassis Ground
    CL +/- Magnetic Clutch
    CODE Transponder Key Amplifier
    DI Fuel Pump Control
    E1... Ground (Earth)
    EFI +/- Traction Control ECU
    EFI +/- Throttle ECU
    EFIF
    EGLS EGR Valve Position
    EGR EGR VSV
    EO1... Ground (Earth)
    EOM Ground (Earth)
    ELS Electric Load Sensor Circuit
    ELS2 Integration Relay
    ELS2 Heated Mirror
    ETC Throttle ECU
    EVAP EVAP VSV
    FC Fuel Pump Relay
    FPU Fuel Pressure Up VSV
    G Distributor
    G+ Camshaft Position
    G22+ Camshaft Position
    HT1... Oxygen Sensor Heater Control
    HTAF1... Air/Fuel Ratio Heater
    IDL Throttle Position Switch
    IGF IGF Signal
    IGSW Ignition Switch
    IGT Igniter/Ignition Coil(s)
    IMLD Theft Deterent ECU
    IMLD To Security Indicator Light
    ISCC IAC Stepper Motor
    ISCO IAC Stepper Motor
    KNK(L/R) Knock Sensor
    KS Mass Air Flow Meter Karmen
    Vortex Type
    LOCK IN A/C Magnetic Clutch Lock
    M+ M- Throttle Control Motor
    MREL Main Relay
    NCO +/- O/D Direct Clutch Speed
    NE+ Crankshaft Position
    NE- Camshaft/Crankshaft Circuit
    NEO ABS & Traction ECU
    NSW Starter Circuit
    OD Overdrive Switch
    OIL A/T Fluid Temp. Sensor
    OMR Engine Oil Feeder Control Motor
    OMT Engine Oil Feeder Control Mtr Relay
    OX* Oxygen Sensor
    PIM Manifold Absolute Pressure
    PM1 Turbo Pressure
    PMC Waste Gate Valve VSV
    PRG EVAP VSV
    PS SW Power Steering Switch
    PTNK Vapor Pressure Sensor Signal
    Appendix B
    Engine Control System Acronyms
    Engine Control Systems I - Course 852 A-15
    Acronym Description Acronym Description
    * Indicates more than one number possible.
    TOYOTA Technical Training A-16
    Appendix B
    R Back Up Light Switch
    RSC IAC (Rotary Solenoid)
    RSO IAC (Rotary Solenoid)
    RXCK Transponder Key Amplifier
    SDL Signal Data Line
    SG Signal Ground
    SDG Signal Data Ground
    SMC Supercharger Magnetic Clutch
    SPD Vehicle Speed
    STA Park/Neutral Switch
    STP Stop Light Switch
    TC Data Link Connector 1
    THA Intake Air Temperature Sensor
    TE1... Data Link Connector 1
    THG EGR Temperature
    THW Engine Coolant Temperature
    THWO A/C Amplifier
    TPC Vapor Pressure Sensor VSV
    TRC +/- Traction Control ECU
    TXCT Transponder Key Amplifier
    VC Voltage Control
    VG Mass air Flow Meter Hot Wire Type
    VPA* Accelerator Pedal Position
    VS Mass Air Flow Meter (Vane Type)
    VSV1 Intake Air Control VSV
    VSV2 Exhaust Gas Control Valve
    VSV3 Exhaust Bypass VSV
    VTO1 Throttle ECU
    VTO2 Throttle ECU
    VTA* Throttle Position
    W Malfunction Indicator
    #10 - #80 Fuel Injectors
    Engine Control Systems I - Course 852 A-17
    A/C Switch Signal A/C SW
    A/C Amplifier A/C (1)
    A/C Amplifier AMC
    A/C Amplifier THWO
    A/C Idle Up Valve ACV
    A/C Magnetic Clutch Lock LOCK IN
    A/C Magnetic Clutch Relay ACMG
    A/C Pressure Switch Relay CF
    A/T Fluid Temp. Sensor OIL
    ABS & Traction ECU NEO
    Accelerator Pedal Position VPA*
    Acoustic Control Intake System ACIS
    ACIS VSV ACIS
    Air Conditioning ACT
    Air/Fuel Ratio Heater HTAF1...
    Air/Fuel Ratio Sensor AF +/-
    Air/Fuel Ratio Sensor AFL +/-
    Air/Fuel Ratio Sensor AFR +/-
    Back Up Light Switch R
    Battery Power BATT
    Battery Power from EFI Relay (+B)
    Camshaft Position G+
    Camshaft Position G22+
    Camshaft/Crankshaft Circuit NECrankshaft
    Position NE+
    Data Link Connector CG
    Data Link Connector 1 TC
    Data Link Connector 1 TE1...
    Distributor G
    EGR Temperature THG
    EGR Valve Position EGLS
    EGR VSV EGR
    Electric Load Sensor Circuit ELS
    Engine Coolant Temperature THW
    Engine Oil Feeder Control Motor OMR
    Engine Oil Feeder Control Mtr Relay OMT
    EVAP VSV EVAP
    EVAP VSV PRG
    Exhaust Bypass VSV VSV3
    Exhaust Gas Control Valve VSV2
    FR-HTR (Hi) Relay B/M
    Fuel Injectors #10 - #80
    Fuel Pressure Up VSV FPU
    Fuel Pump Control DI
    Fuel Pump Relay FC
    Ground ADJ2
    Ground (Earth) E1...
    Ground (Earth) EO1...
    Ground (Earth) EOM
    Heated Mirror ELS2
    IAC Stepper Motor ISCC
    IAC Stepper Motor ISCO
    IAC (Rotary Solenoid) RSC
    IAC (Rotary Solenoid) RSO
    IGF Signal IGF
    Igniter/Ignition Coil(s) IGT
    Ignition Switch IGSW
    Intake Air Control VSV VSV1
    Intake Air Temperature Sensor THA
    Integration Relay ELS2
    Knock Sensor KNK(L/R)
    Magnetic Clutch CL +/-
    Main Relay MREL
    Malfunction Indicator W
    Manifold Absolute Pressure PIM
    Mass Air Flow Meter Hot Wire Type VG
    Mass Air Flow Meter Karmen Vortex Type KS
    Mass Air Flow Meter (Vane Type) VS
    O/D Direct Clutch Speed NCO +/-
    Overdrive Switch OD
    Oxygen Sensor OX*
    Oxygen Sensor Heater Control HT1...
    Park/Neutral Switch STA
    Power Steering Switch PS SW
    Description Acronym Description Acronym
    TOYOTA Technical Training A-18
    Appendix B
    Security Indicator Light IMLD
    Signal Data Ground SDG
    Signal Data Line SDL
    Starter Circuit NSW
    Stop Light Switch STP
    Supercharger Bypass Valve AB1,2,3,4
    Supercharger Bypass Valve VSV ABV
    Supercharger Magnetic Clutch SMC
    Theft Deterrent ECU IMLD
    Throttle Control Motor M+ MThrottle
    ECU EFI +/-
    Throttle ECU ETC
    Throttle ECU VTO1
    Throttle ECU VTO2
    Throttle Position VTA*
    Throttle Position Switch IDL
    Traction Control ECU EFI +/-
    Traction Control ECU TRC +/-
    Transponder Key Amplifier CODE
    Transponder Key Amplifier RXCK
    Transponder Key Amplifier TXCT
    Turbo Pressure PM1
    Vapor Pressure Sensor Signal PTNK
    Vapor Pressure Sensor VSV TPC
    Vehicle Speed SPD
    Voltage Control VC
    Waste Gate Valve VSV PMC
    1g-gze Corona RT132 (Daily)
    RA23 Celica (Project under way)
    RT81 & MS112 (Still Thinking About It!)
    Wife thinks i'm mad (yep... she's right!)
    Acctually... no... The one i was looking for (VSV) wasn't on there... but I might have found the answer elsewhere... I think it mean Vacuum Switching Valve?
    And what is the FPU? Fuel Pressure Up? How is that a component? Just about the ICSV on my schematic is a FPU...
    Aug 2009
    Hey all,
    I've got 2 Q's for all the 1GGTE ECU guru's.
    1.
    I have recently purchased a 1GGTE, came with most everything + Loom, but minus an ECU.
    I have Since sourced an ECU that suits the loom but am still confused as to what Gen the motor is and weather the ECU is suited to the motor.
    I was told it was a Gen 2, being that it has yellow injectors, but when I cross reference the loom plugs with the 1GGTE Gen 3 ECU pin outs sheet, the plugs are the same. Is this because the loom and the ECU plugs are the same between Gen 2 and 3?
    2.
    The engine above mentioned, is going into my Factory manual GA70 / 1GGEU.
    The ECU that i have is an auto, I was wondering as my supra is a factory manual will I need to Bridge the neutral switch? or if there is anything I need to do?
    Cheers Fisher
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    Check the part number on the injectors.
    Pic gen3 ecu and gen2 below.
    http://img4.imageshack.us/img4/3844/090920091.jpg
    Case
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    Quote Originally Posted by v8gz20 View Post
    hi anyone got 1ggte gen1/2 ecu pinouts
    also chasing gen 2 pinouts cant seem to find any
    Junior Member Backyard Mechanic VasH's Avatar
    hopefully this is helpfull
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
  8. #38
    The old One Backyard Mechanic
    Noted earlier advice that
    You can run a Gen3 engine on a Gen2 ECU and loom, but you'll need the injectors (and ballast resistor), and you'll need the different coolant temp sensors. Everything else is pretty much plug and play.
    Not sure that this correct as if I recall the TPS and the Idle control differ and the connectors are very different.
    Cheers Craig
  9. #39
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Anybody have pinouts for the plug found on some GZ20 Soarers (gen 3?) which is located behind the glovebox, it's similar to the one found on MX83's and JZA70's but has 5 extra wires. Here's a pic of how I remember it.
  10. #40
    Nov 2007
    Vash I noticed that pinout chart you posted is not complete, the pinout translations that is. Such as CCO for example is not listed in the table and others.
    Also yes the TPS Connector has more wires on the Gen 3.
  11. #41
    theres some more translations in the manual ill go through and post em up as well.
  12. #42
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    so can anyone tell me what length 1g conrods are, what comp height 1ggte/ze pistons have, and the deck height of 1g's?
    been searching for ages but cant find anything, except conflicting reports about 1g conrods being either 133mm, or 130mm (no definative proof which though)
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
  13. #43
    south austraila
    Quote Originally Posted by MRMOPARMAN View Post
    Cool.. i like this question...
    don't know if this will help..
    1G-GE = 9.0 : 1
    1G-GTE = 8.5 : 1
    1G-GZE = 8.0 : 1
    Project: '82, GA61 XX
  14. #44
    Nov 2007
    I noticed the wiring diagrams posted at the beggining of this thread have the 4 wire TPS.
    http://img157.imageshack.us/img157/3...ecusht2jq1.jpg
    My TPS has 8 Wires. Does anybody have the Diagrams for the Gen 2's 1g-gte's which I believe had the 8 Wire TPS?
    Thanks.
  15. #45
    User Conversion King
    NWA
    ive never seen a "8 wire TPS"
    you must be looking at the wrong sensor.
    take a photo of it
    hello
  1. 1G-GTE tech info/diagrams
    Last Post: 06-01-2008, 12:00 AM
  2. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
