Results 1 to 5 of 5
Thread: 20V won't idle
    Junior Member Backyard Mechanic M.J.H's Avatar
    Default 20V won't idle
    A mate of mine has a 20V in a clubbie and he had the head off recently.
    Put it all back together and was running fine.
    Went to start it a few days later and now it won't idle, Will run fine if you give it a bit of foot to bring the revs up just doesn't want to idle for some reason
    So the questions are
    It may be that it has jumped a tooth on one of the cams and if so would this cause it to not idle properly?
    Or would the likely cause be a dodgy connector somewhere in the loom?
    Will be having a look at the car on Wed night but wanted to get some ideas/tips first.
    My first thought was the cam timing was out but it did idle so who knows.
    Default Re: 20V won't idle
    erm...
    did u do a search? this has been covered lots of times..
    ISCV idle control motor, throttle position sensor and vacuum lines to start with..
    if it has skipped a tooth, u'd get sluggish performance when u rev it up, with some misfiring or rich mix or generally very funny running..
    and if it's a sensor, chances are the car would run very rough than not idle..
    Or a Vac hose has come off...
    ive had this prob before in a clubman
    check both hoses on the idle motor
    one goes to msnifold other goes to intake pipe between air flow meter and intake plenum usually this one is at fault
    Listen to Sideshow.
    Without that one that goes from the cam cover to the pipe between AFM and airbox, it will start, run for 2.5 sec and then die.
  1. ISCV Cleaning (*May* solve poor/erratic idle)
    Last Post: 31-08-2009, 12:57 PM
  2. 4age erratic idle and now not running *URGENT HELP PLEASE*
    By MRMOPARMAN in forum Tech and Conversions
    Last Post: 05-11-2006, 01:23 PM
  3. 1jz problems with idle and snapped off screw head.
    By tyottsoarer in forum Tech and Conversions
    Last Post: 22-05-2006, 11:39 AM
  4. 1jz: unusual high idle on cold-start
    By bk_ in forum Tech and Conversions
    Last Post: 27-04-2006, 07:25 PM
  5. Replies: 9
    Last Post: 21-03-2006, 10:41 AM
