Results 1 to 4 of 4
Thread: 1g-gte stock dump pipe -same flange as anything else?
    Default 1g-gte stock dump pipe -same flange as anything else?
    Hi just did my 1g-gte --> ra23 and i've now got the fun task of making and exhaust! My problem is the 3 bolt flange where the dump pipe bolts up to the cast manifold. Are there any other toyota's that share this flange? I'd prefer not to have to make it, also how does a stock dump (from supra/soarer) fit up in an ra23 ? Thanks in advance!
    Default Re: 1g-gte stock dump pipe -same flange as anything else?
    i can trace my flange in full scale as its not currently fitted if it helps????
    Black Betty >HERE!<
    (\__/)
    We just went through the same situation.. Laser cut / oxy cut flange FTW.
    Oxyfab tech are very cheap for this stuff.
    Or look around for a laser cutter.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    User Conversion King
    NWA
    i measured it all up, drew it in autocad and printed it 1:1 scale, then traced it onto 10mm steel plate. and machined a 1-2mm counterbore for the gasket ring.
    if you havent got cad let me know and ill print-screen it, otherwise give me an email adress
    tolerances are probably ± 1mm. (i measured it by hand)
    hello
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 05:08 AM
  3. 3" dump pipe into 2.5 system is it OK?
    By chrisGT4 in forum Tech and Conversions
    Last Post: 02-11-2006, 01:41 PM
  4. ct26 dump pipe
    By cooter in forum Tech and Conversions
    Last Post: 29-03-2006, 12:02 PM
