Page 11 of 25 FirstFirst ... 91011121321 ... LastLast
Results 151 to 165 of 374
Thread: 1UZ-FE VVTi into IS200
  1. #151
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    Default Re: 1UZ-FE VVTi into IS200
    Yes I can imagine Mos manging to make it run on 6 injectors and the original wiring harness. Because he can. Was disappointed in his need to drill the firewall to fit the clutch pedal
    Friends
  2. #152
    Quote Originally Posted by clubagreenie
    i was highly disappointed that he wouldn't let me near his car with power tools....
    not for lack of offering tho
  3. #153
    good to hear, 'cause my 2j will be getting tuned with an SM4 and no cold start valve
    edit: </thread hijack>
  4. #154
    Penrith BC
    i have pics of this
    ../delete/ban
    tech moderator
  5. #155
    Forum Sponsor Conversion King
    Dec 2006
    ed what size are the stock injectors and what C/R are the vvti 1uz standard as we just took a stab at 300cc and 10.5-1 but it would be nice to know 100%
    linden
  6. #156
    Penrith BC
    265cc and 10.5:1 (pink injectors)
    ../delete/ban
    tech moderator
  7. #157
    Quote Originally Posted by Draven
    I distinctly remember your pet hate of the Microtech on your 1j was that it didn't do any 'cold idle up'.
    Yet here you are today happy as a pig in shit* to run your 2j on Autronic with no 'cold idle up'
    Hmmmm, double standards perhaps ?
    *may be an exaggeration
  8. #158
    More a reflection of each ECU's ability
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  9. #159
    Just because an engine will run happily without one, case in point, my car on the Toyotafest trip, doesn't mean it wasn't a bajillion times better when I got back, sorted it, and had a proper closed loop idle speed.
  10. #160
    I'm sorry, but how can an ECU magically make air?
  11. #161
    not happy as a pig in shit.... just happy it will work since I didn't have an option for a cold start idle-up.
    The vvti plenum doesn't have one, due to FBW, and the plenum I purchased off Jodi had the cold start removed.
    Worse comes to worst, I can always fit a standard 2j plenum and hook up the cold start to the SM4.
    Stop picking on me, I haven't even finished my first coffee of the morning, and it's too cold to deal with your shit
    I think Rod was referring more to the SM4's far superior tuning maps... although I agree that it would probably be nicer with a cold start valve. We shall see, it'll be a very cheap/quick mod to swap it over to a stock plenum if need be.
  12. #162
    Penrith BC
    1uz will have enough throttle leaks for cold start bypass and idle up
    ../delete/ban
    tech moderator
  13. #163
    just because my throttle isn't big enough to fit my head through
    edit: sorry for cluttering your thread with crap Mos
  14. #164
    Orlando - the SM4 has much better coolant temp compensation and tuning, which combined with the 1UZ's throttle leaks mentioned by ed, means that cold starting is a breeze.
    Not so much the case with a more basic ECU - it doesnt have the tuning ability
    ...... butt scratcher?!
  15. #165
    not make air, but perhaps the alteration of timing and fuel, given the same amount of air, during warm up, keep engine stable...
  1. 1uz ITB manifold adapter plate .dxf file
    Last Post: 29-10-2021, 09:49 AM
