Page 9 of 10 FirstFirst ... 78910 LastLast
Results 121 to 135 of 139
Thread: Turbo Preference for 4age
  1. #121
    Junior Member Carport Converter 4agte's Avatar
    Default Re: Turbo Preference for 4age
    just remove the tvis butterflies then block up the holes with a metal epoxy cant rem if you are using just a 4age or gze if its a gze you will need longer studs as the gze ones are shorter
  2. #122
    RWD inlet manifold can bolt directly to the head without the TVIS plate, however it requires some minor filling with a TIG welder in the valleys, cause its too close to the edge of the port, and will leak past the gasket.
  3. #123
    ......................... Carport Converter
    I got a fwd converted inlet manifold, same or different with bolting up and filling??
    MIchael
  4. #124
    Toymods Club Member Backyard Mechanic Big T's Avatar
    If it's a bigport then it'll have the same issues. You'll need the TVIS plate or weld in the valleys.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
  5. #125
    So in summary can someone please give me a list of wat I would need to run LOW BOOST on stock internals!
    Turbo manifold
    t25 turbo
    4agze ECU
    Metal head gasket 1mm
    Anything else, sorry if I sound stupid I just wanna make sure!!
    drive it like you stole it finally got my baby back st162
  6. #126
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    there's a 4agte 16V which made 240 fwkw with a GT2871r turbo
    I have been pruned by old man river!!!!!
  7. #127
    anyone?????
  8. #128
    Junior Member Backyard Mechanic gixer's Avatar
    I run a GT28RS on my turbo 20v, crower rods, Arias pistons, 8.0:1 comp ratio, 550cc injectors, HKS ex mani, running 18psi to 8500rpm, spools very quick.
  9. #129
    sonntag u still in the same timezone? ;p i'l buzzya bit ltr if you are.
  10. #130
    Quote Originally Posted by beso
    nope im in canada if you pm me your number ill give ya a bell
  11. #131
    Quote Originally Posted by moefoe
    Turbo manifold
    t25 turbo
    4agze ECU
    no need at all for a metal HG, just use a factory toyota 4agze jobbie.
    you'll need some oil lines made up (i got 2 x 50cm braided lines with various fittings for 125 quid), fittings for teeing into the heater pipes, hose, hose clamps etc.
  12. #132
    Quote Originally Posted by mrshin
    There's a pic of the HKS turbo mounted on my car from ages ago. I've since downsized a little, but at least it LOOKED cool
    got anymore pics of the quad throttle/pipe work setup? looks awesome.
  13. #133
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Yep, I just discovered this too..but with the FWD bigport manifold.I wondered where all the oily/petrol crap was coming from on top my bigport manifolds runners!
    MrShin, did you 'squash' circular pipe to make the runners that attached to the intake flange on the head? Are those coil packs in the pic a straight bolt in?
    Cheers, Nick.
    == 4AGZE SC14 Supercharged ==
    Now flogg'n the SC14 @ 18psi....
  14. #134
    perth
    hehe your car has powersteering thast about a 3 hp drain
  15. #135
    Instead of paying $700 for a new t25 or t25g.....get a good condition second hand T28 off a S15 they can be got for $700 and under....and i know of a place that has a GTI-R T28 which is the largest of the stock SR T28's released.
    - Luke
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 11:06 AM
  2. 2jz-gte Turbo Oil Feeds
    By dori dori in forum Tech and Conversions
    Last Post: 05-01-2006, 10:26 AM
  3. 5mge turbo
    By pete05 in forum Tech and Conversions
    Last Post: 18-12-2005, 07:23 PM
