Results 1 to 15 of 18
Thread: carby fed 4age.
    Junior Member Grease Monkey rke_011's Avatar
    sa
    Default carby fed 4age.
    just wondering if anyone knows what dizzy is useable on a carby fed 4age..
    can you use standard? if not what is possible for a reasonable price?
    cheers.
    Junior Member Backyard Mechanic Dimitri's Avatar
    Default Re: carby fed 4age.
    www.delta-digital.com.au
    stand alone iginition ecu. would let you run the stock dizzy.
    Thanks Dimitri, good source to keep in the back of my mind.
    Hoppers Crossing
    if you source a haltech IG5 you can also use that as well.
    you can get adaptors in japan to use a 4K dizzy too
    sa
    what would be the easiest/cheapest way around it?
    how much are the stand alone ignition ecu's worth?
    because im guessing sourcing the part from jap land would be long hard and quite expensive...
    i wish i had injection manifolds for it, my carbies hit my brake cyl. and i dunno where i could move it to withot modifying everything..
    i just wanted the ke10 to be a cheap project!!
    haha luckily now i have realised that no ke10/11 with a different motor is easy to do
    cheers for the help guys!
    Pics of aforesaid adaptors.
    Hoppers Crossing
    yes. pics please
    Surely it wouldn't be hard to adapt the internals of a mechanical distributor (eg 22R-E) to a 4A-GE distributor body?
    Hoppers Crossing
    nah i wouldn't think so norbie.
    my old dizzy type for my 4AGE ran some sort of mitsu setup in the guts.
    i've got about 10 4AGE dizzies i should have a look
    you can actually run a 4AGE dizzy using an ignitor off something like a 2TG or whatever to break the spark you just get no advance thats all.
    I ran mine for about five years or so without any advance. Just an ignitor to make it all work, and a careful balance of spark advance so it'd just start when hot.
    26deg was the magic number, though if you can get something to give it advance it'd be a lot better.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Scorcher in victoria made the one i had on my carbed 4ag.
    It was a points type deal, tho i went around and asked about a electric conversion for it, they would sell me a crane kit for 300, or build me a new full electric, mechanical advance one for 400. But this is going 5 years back, so I have no idea what they would charge today.
    Although if i knew what was involved, EFI all the way.
    Dan
    sa
    Quote Originally Posted by Grega
    so you can use the ignitor and get no advance? what will that do? any problems? will it run like crap, whats the benifit of advance?
    and how would you connect an ignitor up? all i know about the dizzy is that there are two electric thingos hangin off it that look like like they need to be plugged in somewhere...
    what do i do with those?
    Just a note on advance's, all Weber manuals recommend NO vacuum advance, mechanical only.
    Quote Originally Posted by Screamn_Sleeka
    Thats interesting, could explain why Ahrensys 5k runs better without vac advance.... Maybe we shall try locking it soon.
    Last Post: 17-06-2008, 08:53 PM
  2. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 06-01-2007, 11:25 PM
  3. 2T/ 3T carby
    By suss_slide in forum Tech and Conversions
    Last Post: 25-08-2006, 10:11 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
