Results 1 to 1 of 1
Thread: HELP: different between BEAMS (RWD n FWD) with standard NA n turbo charged 3SG
    sel
    Post HELP: different between BEAMS (RWD n FWD) with standard NA n turbo charged 3SG
    dear all...
    i started this thread basically to find out more about the common / share parts between the BLACK TOP, RED TOP BEAMS and standard NA or turbo charged 3SG (mostly gen 2 and 3).
    i have collected some info n to share with u all. hopefully with all the knowledge u guys have can correct my "misleading" or wrong info that i have found via internet...
    im from malaysia. currently my RED TOP's head is leaking. im having difficulty to source this engine parts due to is rare. so im having an idea to swap the BLACK TOP to my RED TOP like this but unfortunately the "project manager", Mr. Cheng Khang didnt put any word on it...
    im appreciated if anyone can provide me the part list with part number for these 4 motors - BLACK n RED TOP BEAMS and standard gen 3 3SGE n 3SGTE.
    1. can anyone tell me what is the different between the RED TOP BEAMS oil sump and the standard 3SGE and 3SGTE's? just the extra oil outlet beside the oil filter? the oil filters r different... r the oil filter socket interchangable?! how bout the oil pump, oil strainer and oil pan baffle plate?
    2. anyone have the pix of the BLACK n the RED TOP block?!? can anyone pin point where r those extra oil feeder holes compare with standard 3SG?! suspect these blocks r the same... refer to the TRD spare part list for 270ps BLACK TOP... BLACK TOP's block also has only 1 oil feeder hole like the RED TOP's...
    3. r the inlet cam the same for the BLACK n RED TOP? obviously the exhaust cams for these 2 r different...
    4. how bout the pistons, piston rings, cranks, rods, flywheel, bearing, etc for the standard NA, turbo 3SG and both the BEAMS?!
    5. intake n exhaust manifold? how many stud for these manifold on the BEAMS's heads, standard gen 2 and gen 3 NA and turbo charged's heads? i found out that TRIAL japan used a standard stock turbo charged exhaust manifold to bolt on a turbo... anyone can tell which gen of this 3SGTE's exhaust manifold with turbine?
    i have posted all these in this forum... but have no answer... hope all the toy expert here can clear up these mysteries...
    thanks...
    Last Post: 11-10-2014, 01:02 AM
  2. I have a Hi flowed CT26 and want to upgrade to another turbo..
    By tai_180sx in forum Tech and Conversions
    Last Post: 14-12-2006, 05:35 PM
